G2 Teg Suspension help
Old Jan 30, 2003 | 08:22 PM
Ekliptix's Avatar
New User
Default G2 Teg Suspension help
I think the AGX are ok down to 1.5" which would be ok(if that took off enough gap), but since I need GR2's in the rear, I wouldn't be as tunable + the GR2's are called "moderate" for sportiness by their manufactures.
But I guess a more year-round-friendly height w/ non adjutable dampeners would be better value.
edit: I just found out that rear EF AGX's fit DA tegs. But coilovers are req to achieve a level height.
The Eibach Sportlines are too soft though. 263F/143R
So if it's springs I'm getting it'll probably be Neuspeed(Sport 1.8) of H&R(Sport 1.8"Front: 340lbs.Rear: 186lbs.).
Value options:
Non adjustable shock(Tokico Blues, Koni Reds)
with "sport" drop. I would prefer a progressive spring.
The softer Eibachs are 0.3" lower in the front which evens the gap.
some prices here:
http://www.optauto.com/webstore/prod...1360&last=1360
17" wheels.
Input?
Old Jan 30, 2003 | 09:40 PM
Slain's Avatar
Default Re: G2 Teg Suspension help (Ekliptix)
You can use a DC or a EG shocks as long as you use the front forks off of a dc or eg.. the rear is the same
djteggy99
Apr 9, 2008 04:33 PM
Team Underground Teg
Dec 23, 2004 09:04 AM
phivelug
Oct 12, 2004 10:12 AM
projectTeG
Oct 22, 2003 04:28 PM
Regular Series
Jun 1, 2002 10:02 PM
