VSS questions about location and function
Old Jan 30, 2003 | 07:16 PM
USDM 4G VTEC's Avatar
Default VSS questions about location and function
k as far as the searches i have done in the archives it seemes the VSS its located behind the Cluster... and sends a signal to the ecu and tells it the car its moving...
whats the thing on the tranny in wich the speedo cable gets plugged into???
any name for that?
k heres the deal... today on my way to meet a buddy , my speedo started jumping and a few min later its stopped working... i tried a few times to make sure the cable was inserted and it was... i dont have a pin since i lost it when i swaped (but never game me prob on the last 8 mths) anyhow.. i played with it a lil and the metal tip of the cable its a lil loose of the cable black cover itself.. i tiighten that and inserted it... the cable its inserted.. but doesnt wanna work..
have u heard or seen that the place in wich u plug the cable goes bad??? do i have to use my Si or STD tranny plug thingy in order to make my speedo work?? bc i turn the cable by hand and it moves..... i drove for a while and didnt work... 2 hrs later i leave and it worked fine but ust jumped a lil.. but 10 min later it stopped working
any inputs on this case... i know i need a new speedo cable if u have one, or can get one PM me and give me a price, thanxs
any input will be great
Old Jan 30, 2003 | 08:48 PM
EF_LSVtec's Avatar
Default Re: VSS questions about location and function (JDM EF9)
this is what you do, take the cluster out and run the car with the cable connected to your tranny...see if the cable turns while you're driving...if not, just push it in some more or replace your cable and get a clip.
Old Jan 30, 2003 | 08:53 PM
Trinity's Avatar
Default Re: VSS questions about location and function (EF_LSVtec)
its 15 bucks from honda so i would just get a brand new one and basically the guy above me told ya what to do
its just like a little clip
Old Jan 30, 2003 | 09:57 PM
Creamies's Avatar
Default Re: VSS questions about location and function (Trinity)
yeah, its a pain in the butt to align.
Old Jan 31, 2003 | 05:24 AM
k thanxs
u know if the VSS its the thing behind the speedo??
Old Jan 31, 2003 | 07:02 AM
ricodemus's Avatar
the vss is the thing that sits in your tranny that has that cable connected to it.
Old Jan 31, 2003 | 06:10 PM
Default Re: VSS questions about location and function (ricodemus)
THANXS A LOT
a lot of other post on search say its on the cluster... i am happy to beleive u and for the future reference sakes this it the right answer!
also doesnt anyone here has a wrecked EF that can sell me the speedo cable
and another question is, that if my Si VSS can be able to be swaped with the DX one with no problems
Old Jan 31, 2003 | 10:19 PM
ricodemus's Avatar
I have read that almost any (dseries and bseries) vss's can be swapped, obviously only if its the right kind for your application (mechanical should be swapped with a mechanical, electronic with a electronic). I guess what I'm saying is that you shouldnt have a problem swapping your dx with your si.
GPC91
Sep 17, 2012 01:11 PM
crxblues
Dec 6, 2006 10:44 AM
philkehn
13
Sep 16, 2006 02:03 PM
IhEARTjDM2
Oct 24, 2005 02:39 PM
JapJunkie
11
Sep 16, 2004 01:57 PM
