Brake Upgrade
Old Jan 30, 2003 | 06:33 PM
RiceRocket16's Avatar
Default Brake Upgrade
Will the EX calipers fit on a 93 DX? I know that i can buy an EX saddle and caliper and that it will fit if the hub is the same on both models. Also, would a 99 Si caliper and saddle fit on my car??
Old Jan 30, 2003 | 06:40 PM
NonovUrbizniz's Avatar
Loved
Default Re: Brake Upgrade (RiceRocket16)
there is no difference between ex and dx brake calipers.
so i guess the answer is yes. but it's not an upgrade. the only model integra/civic that came with larger front rotors and calipers are the type-r's. and yes they also fit but I think you need the steering knuckles from the type-r.
Old Jan 30, 2003 | 06:44 PM
joe_bocc's Avatar
Default Re: Brake Upgrade (NonovUrbizniz)
Actually, all Integras and the Civic Si and EX came with larger front rotors and possibly calipers as well.
Old Jan 30, 2003 | 06:52 PM
shawnhayes's Avatar
And, of course, to illustrate the point:
http://hybrid2.honda-perf.org/tech/bigbrakesbymcp.html
The EX and Si model of the 92-95 Civic had calipers manufactured by Nissin.
The CX, DX, and VX had calipers manufactured by Akebono.
The base of all good upgrades on Civics is the steering knuckle from an EX (or Si) with the Nissin mounting points. Please don't say if you don't know.
The EX caliper will not fit on a 92-95 DX without the steering knuckle from either an EX/Si or an Integra. The hub is the same size and pattern, but the EX/Si discs are slightly larger. It is most certainly an upgrade, and also why Honda put them on the EX and Si.
Shawn
[Modified by shawnhayes, 10:54 PM 1/30/2003]
Old Jan 30, 2003 | 06:53 PM
Loved
Default Re: Brake Upgrade (joe_bocc)
oh righhhht the akebono brakes or whatever.
sorry my bad.
Old Jan 30, 2003 | 06:56 PM
shawnhayes's Avatar
sorry my bad.
hmm. Maybe I shouldn't have been so harsh. I don't have any history with you, so I didn't know if you were a newbie with an attitude. Don't take it personal. We're rough.
Shawn
Old Jan 30, 2003 | 07:32 PM
43MA's Avatar
aren't they both 9.5in rotors?
Old Jan 31, 2003 | 07:34 AM
CXHatchback's Avatar
Default Re: Brake Upgrade (Steady)
EX/Si/Integras (exc. r) have 10.4 in rotors w/nissin calipers. Everything else is 9.5" w/akebono calipers.
Also, it's good to note that even thought the ex/si and integra calipers are both nissin, the piston on the teg calipers have a larger bore, so even if you have an ex, you can upgrade to teg calipers and still see an improvement.
DaEJKid
Sep 27, 2007 05:45 PM
pd0019
Honda Civic (2006 - 2015)
11
Jan 26, 2007 03:24 AM
Fatty_1775
Jun 6, 2006 12:32 PM
.dave
Nov 25, 2003 06:34 AM
xXx Justin xXx
Apr 27, 2003 10:36 AM
