v-afc wiring problems...help!!
Old Jan 30, 2003 | 05:54 PM
Mad Cow Disease's Avatar
Default v-afc wiring problems...help!!
ok guys, heres the scoop: i got a 88 crx dx with a d16zg running on a pm7 ecu..and i just wired up a v-afc...thing is, after i'm done, i get a check engine light: codes 6, 9, 10, 13, and 20. what the hell? it never had a check engine light on before this...could it be a bad or missing ground somewhere? help!!
Old Jan 30, 2003 | 06:01 PM
PaImportTuner's Avatar
Default Re: v-afc wiring problems...help!! (tmc racing)
ok by any chance what wiring diagram did you use??
Old Jan 30, 2003 | 06:08 PM
Default Re: v-afc wiring problems...help!! (PaImportTuner)
i used a pr3 diagram to tap into the harness
Old Jan 30, 2003 | 06:16 PM
pg7 would be the same as the pm6 wiring. right?
Old Jan 30, 2003 | 08:19 PM
your diagram would be WH-1 or H-1 i forgot which one it is
its the top left picture on the ecu plugs (3 plugs)
a o
o o
o o
o o
it being the "a" (H-1) on the page use that one.
MadVtak
Jul 27, 2007 10:22 AM
dkk119
May 24, 2006 05:44 PM
deca
Jan 19, 2005 03:02 PM
fireslinge
Aug 10, 2004 10:54 AM
DARKDOGG
Jul 15, 2004 07:10 AM
