sway bars and strut bars
Old Jan 30, 2003 | 05:24 PM
PEARLWHITE's Avatar
Default sway bars>?
is it good to get strut bars???
if so what should i get and which bars???
Old Jan 30, 2003 | 05:31 PM
sslude's Avatar
Default Re: sway bars>? (PEARLWHITE)
swap bars reduce sway, strut bars stiffen the body.
Old Jan 30, 2003 | 09:58 PM
PEARLWHITE's Avatar
Default Re: sway bars>? (sslude)
so get em???
what kind and which bars??WHERE TO GET THEM ALSO
thanks
Old Jan 30, 2003 | 10:06 PM
RAB's Avatar
RAB
Subject title: Sway bars
then you go into strut bars I hope you know there two different things.
As far as I know Sway bars reduce body roll and Strut bars reduce body flex which increase stiffness.
Old Feb 3, 2003 | 10:01 PM
Greshlude's Avatar
it's good to get both. as for what kind, it all depends on what kind of car you have. if you have a 3rd gen, your choices are slim, but if you have a 4th or 5th gen, you have tons of choices.
Old Feb 3, 2003 | 11:17 PM
PrecisionH23a's Avatar
Default Re: sway bars>? (Greshlude)
bump, id like to know what kind of SWAY bars i should get for my 4th gen as well as prices.
Old Feb 4, 2003 | 05:34 AM
illusion's Avatar
Default Re: sway bars>? (GudeH23a)
suspension techniques are in hte $125 range. for neuspeed.. double that.
Old Feb 4, 2003 | 06:00 AM
ViZ's Avatar
ViZ
Default Re: sway bars>? (illusion)
has anyone had fitment issues with the suspension techniques?
Old Feb 4, 2003 | 06:37 AM
Firedrake's Avatar
Default Re: sway bars>? (ViZ)
Almost everyone I know who has gotten bigger sway's on a prelude has torn out the subframe where the bar attaches to the frame......just an FYI for people considering them.....
Brian
Old Feb 4, 2003 | 06:52 AM
Honda318dx's Avatar
Default Re: sway bars>? (Firedrake)
ST rear swaybar only, works great, cheap and easy to install.. A "must" upgrade! Highly reduces understeer..
Strut bars.. Um, Ebay ones... CHEAP!
Old Feb 4, 2003 | 08:41 AM
Xlerate9's Avatar
Default Re: sway bars>? (Honda318dx)
Neuspeed Strut Bars. Got mine for $118 shipped from nopionline.com. They are all one peice so it reduces flex. I Def. Recommend them.
Old Feb 4, 2003 | 08:56 AM
rjr162's Avatar
Default Re: sway bars>? (Xlerate9)
My friend has a 2001 VW golf, which he always complained he never liked the handling on. He's since then switched to 17" 5Zigen Fireball rims, and installed a neuspeed strut bar and lower sway bar. I drove it the other day, and I can say I definantly noticed a difference. It handles better now than my 97 base which suspension wise at this point is stock.
Old Feb 4, 2003 | 09:22 AM
LudEcrous's Avatar
Where is a good place to get them pricewise?
Old Feb 4, 2003 | 09:35 AM
Casual Gcode1's Avatar
Default Re: sway bars>? (LudEcrous)
Anyone looking to buy a suspension techniques front sway bar?
Old Feb 4, 2003 | 10:40 AM
95PreludeSi's Avatar
Default Re: sway bars>? (Casual Gcode1)
When you upgrade your sway bars don't you usually go with a thinner bar up front and a thicker (or solid if your stock rear is hollow) to reduce understeer?
In short when upgrading your getting bigger in the rear and smaller up front? BTW - A freind I know has ST sway bars for his MKIII Supra and likes them.
-Mike-
Old Feb 4, 2003 | 10:43 AM
YodiBrodi's Avatar
Brian
i heard that was sometimes a problem on the civics but never on the prelude/accord. in fact i heard that it whouldn't be a concern. anyone else had any experience with this subframe tear thing other than firedrake?
Old Feb 4, 2003 | 12:16 PM
GrantTPC's Avatar
Default Re: sway bars>? (YodiBrodi)
I havea 28mm rear swaybar. It tore out.. three times.
First time it pulled the weld-on bolts out of the subframe so I welded the nuts back on.. then it tore the welds out. So I welded the mounting bracket directly to the frame rail.. It tore a square chunk out of my subframe.. Finally, I ended up welding a 1/4" thick steel plate to the missing section in the subframe and bolted the bracket to it through the floor of my trunk using 8" long 1/2" diameter bolts with another 1/4" thick steel plate on the trunk floor acting as a washer.. It's fine now...
I haven't heard of people having trouble with bars smaller than 28mm...
Old Feb 4, 2003 | 06:38 PM
dilligaph's Avatar
Default Re: sway bars>? (GrantTPC)
I also would like to know more about experiences and recommendations for sway and strut bars for my 4th gen. I am going STS this year, so any additional information yall have would be appreciated!
Thanks
Old Feb 4, 2003 | 07:10 PM
Final Flash's Avatar
From what I've seen, the ST stuff is pretty much around the same price wherever you look, but I buy at www.optauto.com a lot, and they have them so try there.
As far as the braces, my front brace tightened my **** up a lot. There's a guy selling some left over Spoon front & rear braces around here sometimes, I think he advertised them in another post on this same topic.
RotaryPWR
Aug 14, 2009 10:27 PM
kalbs
Suspension & Brakes
12
Aug 15, 2007 06:33 PM
Paratrooper
Mar 1, 2004 10:31 AM
importboi22
Dec 28, 2003 08:36 PM
ShiftStain
Oct 21, 2003 08:36 PM
