I need motor specs between the F22b1 and F22b2.
I just picked up a f22b1 for an extra motor, thinking about building it..
But before i do anything, i was thinking today..
Is the bore and stroke the same on these two motors, along with compression, i know the f22b2 is 8:8:1.
How about the head? Are they interchangable?
Anyways, does anyone have the internal specs on both of these motors?
Any help would be great thank you.
[Modified by BottleFedBigBodyLX, 7:37 PM 1/30/2003]
The only difference between F22B1 and 2 is the head. # head is VTEC, #2 head is not. They are interchangeable. But since you have the VTEC engine, there's no point in trying to swap heads.
Jeff
Jeff
Correct me if im wrong, but isnt the f22b1 OBD I and the f22b2 OBD II.
now if you have a LX it would be a non-vtec? EX would be Vtec? Im running a non-vtec motor right now. I really dont care as if either motor is Vtec or non Vtec.
I know his is non Vtec along with mine.. I was just curious on internal specs on both motors.
tell me if i am wrong, thanks.
95 GaNgStA AcCoRd- thanks for the advice i will do that.
noslude how you doing? what beer are you on now? number 8 ha ha.. damn
[Modified by BottleFedBigBodyLX, 8:38 PM 1/30/2003]
i stand corrected..
anyways..
Does anyone have any actual specs?
Im looking for numbers here! ha ha..
Bore, Stroke, head specs, clearence specs thanks.
this page is called honda-tech for a reason right? come on peeps.
[Modified by BottleFedBigBodyLX, 9:21 PM 1/30/2003]
anyways..
F22b1
Bore 85mm
Stroke 95mm
Not sure what "head specs" youre looking for
Clearances? Bearings? Ring Gap?
Help us help you by letting us know specific questions so I dont have to type the manual
Bore 85mm
Stroke 95mm
F22A1 SOHC non-vtec 8.8:1CR 125hp 137lb/ft 4G 90-93 USDM DX/LX 85b/95s
F22A4 SOHC non-vtec 8.8:1CR 130hp 142lb/ft 4G 90-91 USDM EX 85b/95s
F22A6 SOHC non-vtec 8.8:1CR 140hp 142lb/ft 4G 92-93 USDM EX 85b/95s
F22B1 SOHC vtec 8.8:1CR 145hp 147lb/ft 5G 94-97 USDM EX 85b/95s
F22B2 SOHC non-vtec 8.8:1CR 130hp 139lb/ft 5G 94-97 USDM DX/LX 85b/95s
F23A1 SOHC vtec 9.3:1CR 150hp 152lb/ft 6G 98-02 USDM EX/LX 86b/87s
F23A5 SOHC non-vtec 9.3:1CR 145hp 135lb/ft 6G 98-02 USDM DX 86b/87s
F20A DOHC non-vtec 9.5:1CR 150hp 137lb/ft 4G 90-93 JDM 2.0Si 85b/??s
F20B DOHC vtec ?.?:1CR 200hp ???lb/ft 6G 98-02 JDM SiR-T 85b/??s
F20C1 DOHC vtec 11.0:1CR 240hp 162lb/ft --- NA-NA USDM S2000 87b/84s
F22B DOHC non-vtec 9.8:1CR 160hp 148lb/ft --- NA-NA JDM Prelude Si 87b/??s
Type A bore: 85.010-85.020
Type B bore: 85.000-85.010
Can be bored to .25 over: 85.0250-85.260
or .50 over: 85.500-85.510
Pistons type A: 84.980-84.990
Type B: 84.970-84.890
.25 over: 85.230-85.240
.50 over: 85.480-85.490
Piston to cyl: .020-.040
All above in mm
All above in mm
i could care less right now....
just go to http://www.accordinglydone.com
there is a very excellent data right up on all honda engines.
foxxor
Jul 26, 2007 12:48 PM
