Is it possible to run toda B's with stock valvetrain?
Old Jan 30, 2003 | 10:02 AM
JdmVetteEater
Guest
Posts: n/a
Default Is it possible to run toda B's with stock valvetrain?
Like the topic says. And the car is a 2000 civic si.
Old Jan 30, 2003 | 10:22 AM
ITRinEJ1's Avatar
Default Re: Is it possible to run toda B's with stock valvetrain? (JdmVetteEater)
if you dont go beyond the stock rev limiter
its not really recommended anyways, just get the valvetrain if ur gonna shell out the dough for that already!!
Old Jan 30, 2003 | 10:56 AM
VTEC-DA's Avatar
Default Re: Is it possible to run toda B's with stock valvetrain? (ITRinEJ1)
Even going to the stock rev limiter I wouldnt feel safe. Plus, by only going as high as a stock Si, your not really taking advantage of the cams. Wait till you can afford the springs/retainers also. You will be much more pleased if you do.
Old Jan 30, 2003 | 11:17 AM
Nameless RB26's Avatar
Default Re: Is it possible to run toda B's with stock valvetrain? (VTEC-DA)
I think you should wait. Bigger cams will push the valve springs further than they were made to go (stressing them out). Upgrade it all...
Old Jan 30, 2003 | 11:19 AM
vtecvoodoo's Avatar
Future Texas Boy
boost it.
Old Jan 30, 2003 | 11:21 AM
euclid's Avatar
Default Re: Is it possible to run toda B's with stock valvetrain? (vtecvoodoo)
negative, they will float and most likely break, and the b's are rumored to have breakage problems even with the whole valvetrain.
Old Jan 30, 2003 | 12:02 PM
ajchen's Avatar
there's an intelligent response.
the answer to your question is no. float = bad.
boost it.
Old Jan 30, 2003 | 12:07 PM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: Is it possible to run toda B's with stock valvetrain? (ajchen)
It`s called an opinion. He got mine wether he wanted it or not. Isn`t this country great.
"float=bad" is pretty good too. That must be the technical term.
[Modified by vtecvoodoo, 1:08 PM 1/30/2003]
Old Jan 30, 2003 | 12:11 PM
COLORPROS's Avatar
Hey vetteater I know someone in your hometown w/some Jun stage 3s for sale.Buy some valvetrain if you want to go all motor.Quit skimpin
tech6804
Oct 5, 2004 04:00 PM
mrtrex
Jul 27, 2004 10:33 PM
typevimports
Jun 26, 2002 05:43 AM
nsx-Animal
Sep 20, 2001 12:50 PM
nsx-Animal
Jul 2, 2001 02:42 PM
