two part question
Old May 21, 2001 | 06:23 AM
frank5079's Avatar
Default two part question
I've got an '84 CRX DX, and am in the middle of doing a teg swap. I have two questions that I need help with. First, should I go with the teg axles or two short rex axles? I do want to swap in the larger teg discs and calipers. Second, I am at a loss to figure how I can position my teg fuel pump, since I don't have an Si bracket. Do you guys have any suggestions? Please advise.
Old May 21, 2001 | 07:02 AM
c-rex's Avatar
Default Re: two part question (frank5079)
You will have to use the teg axles, and the Teg Hubs. Also, you will have to run a bigger return line going from Carb--> FI. I started this swap a while back in my civic. I had a 87 Crx Si ans a 85 Civic 1500, I converted it to FI, It was a B*tch! Took me nearly 3 days to do *most* of the work. Its still not done, I have to run new Fuel line, hook up dash wiring, and try to make everything else work. What a pain. As for the pump, Just make a custom bracket. Or use the teg bracket, and modify it. Best advice I got. HTH, let me know if you need more.
~C~
cadwiese
Feb 19, 2010 09:19 PM
RHGSR01
Oct 3, 2004 04:43 AM
paulzy
Jan 2, 2002 04:35 AM
