need help guys, car wont start up after rebuild head
Old Jan 30, 2003 | 06:53 AM
whitelightning's Avatar
Default need help guys, car wont start up after rebuild head
well after over 2 months, i've completed the rebuild of my head, consisting of 00 itr cam/ valvesprings new headgasket seals etc...
car would not start it cranks has fuel i'm sure because one of my injectors were leaking...i checked the plugs-ok, wires are correct going into distributor also.
I also picked up a new battery so there's plenty of juice...the car cranks, turns, coughs but wont' start up and run!!!!!!!!!!!!!I 've got white cloud of smoke coming out of my throttle body, don't know what that is....
-could this be a timing issue???i have skunkworks (old school cam gears) when i set them at TDC i had the lines on the gears pointed at eachother exh cam gear at 3 o clock and int cam at 9 o'clock...is this correct could this be my prob???? HELP is greatly appreciated again!!!!
Old Jan 30, 2003 | 08:05 AM
flip b18b's Avatar
Default Re: need help guys, car wont start up after rebuild head (gr8gribbs)
it sounds like a timing problem i wish i could help ya more but check the cam gears maybe try moving your dist
Old Jan 30, 2003 | 08:29 AM
Default Re: need help guys, car wont start up after rebuild head (flip b18b)
i'm thinking so too, i think i set the cam gears incorrect at TDC, not sure if i did, should the timing marks on the skunkworks cam gear be pointed up????i had them pointed at eachother...still doing a search
Old Jan 30, 2003 | 11:31 AM
Default Re: need help guys, car wont start up after rebuild head (whitelightning)
anyone????
Old Jan 30, 2003 | 04:30 PM
CivicEK.PDX's Avatar
On the cam gears the number and markings should be facing up. Sounds like a timing issue with the cams.
o_Rage_o
Nov 10, 2016 06:32 PM
sh4k3r
Jan 23, 2011 01:03 PM
unrealgtx
Aug 10, 2007 05:50 PM
Mr. Stiles
Apr 29, 2006 10:02 AM
dsadas89das78934
22
Jan 24, 2004 04:37 PM
