Forged/Cast Rims
Old Jan 29, 2003 | 11:43 PM
j_ambrose's Avatar
Default Forged/Cast Rims
I am buying some 5zigen rims soon(Beckets I believe most of you will know them as) and I'm just a little confused about the two different types. The FN-O1Rc's are cast and the FN-O1R's are forged.
I was wondering what the difference between forged and cast rims are? Thanks in Advance.
Old Jan 29, 2003 | 11:46 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Forged/Cast Rims (WhiteEJOne)
Forged are what they are, forged out of a solid piece of aluminum/bronze/magnesium/ whatever
Cats wheels is when the metal is melted and poured into a cast.
Old Jan 29, 2003 | 11:52 PM
j_ambrose's Avatar
Default Re: Forged/Cast Rims (Emerica)
Is one stronger than the other? Or lighter?
Old Jan 30, 2003 | 12:28 AM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
i think forged is lighter and stronger
Old Jan 30, 2003 | 12:58 AM
euclid's Avatar
Default Re: Forged/Cast Rims (CiRcUiTsi)
are forged wheels stamped or machined... if they are stamped i would assume they would be nearly unbreakable
Old Jan 30, 2003 | 01:16 AM
DSC's Avatar
DSC
Forged is harder, lighter, and more expensiver
I wanna get a set too.
Old Jan 30, 2003 | 01:18 PM
j_ambrose's Avatar
Default Re: Forged/Cast Rims (DSC)
and more expensiver
Yeah that's what I figured but its worth it right .
Old Jan 30, 2003 | 01:21 PM
Evs-One's Avatar
Solbros Owns Me
forged are deffinately way stronger and lighter...worth the extra penny.
Old Jan 30, 2003 | 01:23 PM
nd8ch's Avatar
just wondering, but how is a solid piece of aluminum formed? they had to have had the rim in some form before they forge it...would they mold it into a block first?
Old Jan 30, 2003 | 06:41 PM
joe_bocc's Avatar
Default Re: Forged/Cast Rims (nd8ch)
Usually, the wheel starts out as a saucer(sp?). The saucer is eated and then it is pressed by a machine into the desired shape using multiple thousands of pounds of pressure.
Old Jan 30, 2003 | 06:45 PM
shawnhayes's Avatar
While forged wheels are "harder" they are also more "brittle". Once the shear stresses exceed the rims ability to contain it, a forged wheel will break where a steel rim will bend or a cast one will deform.
Bad potholes are the serious enemy of low profile tires on forged rims. That's a thousand dollars waiting to run down the drain right there.
Shawn
Old Jan 30, 2003 | 07:44 PM
the DR.'s Avatar
Default Re: Forged/Cast Rims (shawnhayes)
forged wheels are lighter as opposed to cast wheels, only because the forged wheels require less amount of material to have the same strength as its cast couterpart, the cast wheel must be 'thicker' to have the same strength, therefore its a bit heavier.
Old Jan 30, 2003 | 10:22 PM
j_ambrose's Avatar
Well would 45 series on a 16"rim be too low profile for street driving? I really don't feel like wasting a thousand dollars. If so I guess I'll just get the cast version.
Thanks for all the help guys.
Old Jan 31, 2003 | 01:03 AM
DSC's Avatar
DSC
Yea thats why I didnt say they were stronger
Old Jan 31, 2003 | 03:31 AM
DCStreetHtch's Avatar
i'm aware that my SSR's are forged/spun... someone are to explain the "spun" part??
-Bryan-
Old Jan 31, 2003 | 05:10 AM
BlueBalls's Avatar
i have 205/45/16 and IMO that is the perfect size for my si. i've had 17" wheels and the with the 35 series profile the tires kept getting bung all the time. go for the forged wheels, the light weight of them makes a huge difference
Old Jan 31, 2003 | 05:31 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: Forged/Cast Rims (BlueBalls)
I went over some railroad tracks faster then I should've (I mean really fast) and I bent to of my Volks. They were bent not broken. I had them straighten'd out and I was good to go.
Old Jan 31, 2003 | 10:53 PM
nd8ch's Avatar
Default Re: Forged/Cast Rims (Apex i ITR)
now that you guys talk about the problems with 17's, and my friend's rim recently being bent by an unknown factor...im considering 16's now. I figure 17's are nice and corner better, but 16s are probably better for street, and cost efficient. oh yeah, i fgure since my car wont ever look so good, i might as well concentrate on performance. can you feel the difference in cornering between a 16' rim and a 17' rim?
[Modified by nd8ch, 7:54 AM 2/1/2003]
Old Feb 2, 2003 | 02:53 PM
j_ambrose's Avatar
Thanks for the help everyone. I'll probably go with the forged ones in 16" with a 45 series tire. Hopefully I won't break any rims.
Old Feb 2, 2003 | 05:49 PM
shawnhayes's Avatar
Volks are generally a cut above. The process of "ultralight" forging causes the brittleness. Some of the wheels that are forged are thought out and processed differently, thus the improved reliability.
Not all forged wheels are brittle, but some are. Customer feedback is a very good way to gauge a wheels reliability, and your comment speaks well for volks.
Shawn
250r king
22
May 7, 2009 08:04 AM
Black Diamond
Apr 20, 2009 07:59 PM
Drum_Guru
11
Apr 19, 2004 06:04 AM
ITR1071
Oct 10, 2002 07:27 AM
Chris_R
Sep 5, 2001 09:35 PM
