just got a fake itr shift knob and...
Old Jan 29, 2003 | 07:11 PM
Buckshot's Avatar
Default just got a fake itr shift **** and...
the god damn mother ****** wont thread on
i mean u think a fake itr **** so it would fit an integra...wtf is going on here
i remember one of my friends havin the same probs too..cept his went down farther..mine only goes down a few threads
am i just stupid or what
Old Jan 29, 2003 | 09:28 PM
Danger's Avatar
Default Re: just got a fake itr shift **** and... (Buckshot)
send it back
Old Jan 29, 2003 | 09:38 PM
Specialk's Avatar
Default Re: just got a fake itr shift **** and... (JonnyDanger)
just hit with a hammer a couple times itll go on....trust me. jk.
Old Jan 29, 2003 | 09:53 PM
ingrate's Avatar
25 Year Member
Default Re: just got a fake itr shift **** and... (Specialk)
*WARNING*
What i did was take a dremel to the threads of the shifter to make it shorter, probably by about 1/2" or so. I put newspaper/plastic bags all over my interior to protect from the metal shreds. For some odd reason the **** was able to go on now. But later on when i bought a real ITR **** it wouldn't fit, so i just ended up buying another stock shifter.
FYI, if you don't want to dremel your shifter, i still have my old cut shifter if you want it. I'm thinking it should fit your ****. I'll let it go for free+s/h if you want it. It's just been sitting here for the past couple odd years. just let me know
Old Jan 29, 2003 | 10:58 PM
tC_Dragon's Avatar
Default Re: just got a fake itr shift **** and... (In7egrity)
out of curiousity... what kinda of shifter are you using?? and what **** were you using with it previously??
Because, if you are using the stock **** which has a plastic center, then regardless of the shifter threading, it will pretty much thread onto any shifter(even if the shifter is threaded improperly). And so if you try and put a metal **** on there, then it might not work.
This actually happen with skunk2 short shifters for one batch, they went out with the wrong threading.
Old Jan 29, 2003 | 11:08 PM
vtec95's Avatar
Default Re: just got a fake itr shift **** and... (pdcdragon)
I put a typr r shift boot and shifter and it doesnt look good. The bag hangs too low, so I just used my original shifter and it looks better. You dont actually see the shifter.
Old Jan 30, 2003 | 03:49 AM
IC x Prince's Avatar
New User
Default Re: just got a fake itr shift **** and... (vtec95)
that is the way they all are, it grew on me and I like it better.
Old Jan 30, 2003 | 04:17 AM
JeremyL's Avatar
Default Re: just got a fake itr shift **** and... (UltraPrince)
i have two, 1 in mine and 1 in my gf's, they both threaded on fine but you have to align it right with the nut
Old Jan 30, 2003 | 06:46 AM
samagon's Avatar
I had the same thing, then I broke the plastic ring around the top of the boot, that holds it up over the neck of the shifter, and now you can see the shaft all the way down, and the boot is crumpled down at the bottom. I like the look, but it gets dirty really easily
Old Jan 30, 2003 | 08:02 AM
Buckshot's Avatar
Default Re: just got a fake itr shift **** and... (JeremyL)
yea it came with a nut...how exactly do you allign it
and i was using the stock gsr **** before with some cheap after market ss
Old Jan 30, 2003 | 08:37 AM
au-gsr's Avatar
1-screw the bolt, washer side up,all the way down. not tight-more like jsut sitting there.
2- screw on you shiftknob until it contacts the bolt. don't tighten it down yet.
3-grab 14mm or 9/16" or whatever size you need and align the shiftknob the way you want it.
4-then hold the **** inyour hand-aligned-and use the 14mm wrench to tighten up on the ****.
couldn't get the other had in the picture becasue i had to take the picture, but imagine it holding the shiftknob in place as i turn the bolt with the wrench to the right
FINISHED PRODUCT a lil blurry though
[Modified by au-gsr, 10:40 AM 1/30/2003]
Old Jan 30, 2003 | 10:01 AM
Hexxboy's Avatar
New User
<rice advice>
I prefer it w/o the nut. Using the nut takes up thread space, so if u want your **** to sit the lowest possible leave it out.
If your having problems with it aligning to the point where it tightens up, try stuffing some bits of cardboard paper or something in the ****.
</rice advice>
Old Jan 30, 2003 | 10:05 AM
dip-set's Avatar
Default Re: just got a fake itr shift **** and... (Hexxboy)
where can i pick up a red stitched leather cover like that....?
Old Jan 30, 2003 | 10:26 AM
Buckshot's Avatar
Default Re: just got a fake itr shift **** and... (teg-your-it)
its a jdm itr one...
thanks for the pics..but the prob is i cant even get it to go but a few threads..i can still see like 1in of threads below it so im pretty much fucked..
im thinkin about just gettin a mugen one..anyone have experiences with one?
Old Jan 30, 2003 | 10:28 AM
Solipsist's Avatar
HAMERR GOOD!!!!!
Old Jan 30, 2003 | 10:29 AM
Solipsist's Avatar
HAMMER GOOD!!!!!
Old Jan 30, 2003 | 11:00 AM
IntEGNYC's Avatar
Default Re: just got a fake itr shift **** and... (TEXASLS95)
looks like this guy likes hammering :D
Old Jan 30, 2003 | 04:59 PM
mugenracer's Avatar
[QUOTE]where can i pick up a red stitched leather cover like that....?
QUOTE]
I bought a 1996 JDM ITR center console from a friend complete with ashtray/drinks holder and the shift boot is just plain black, no red stitching, not that it makes much of a difference to me!
Old Jan 30, 2003 | 05:19 PM
junglistgsr's Avatar
i dont wanna nit pick....but the quote in your sig is wrong.
its really: the things you own end up owning you
Old Jan 30, 2003 | 05:28 PM
TheRoxorcist's Avatar
Default Re: just got a fake itr shift **** and... (au-gsr)
what size is the bolt? i have a type r **** i bought off some guy but he didn't have the locking bolt for me. need to go to lowe's or something to find the right size... just didn't know what size fits around the stock shifter
Old Jan 30, 2003 | 05:38 PM
Buckshot's Avatar
Default Re: just got a fake itr shift **** and... (TheRoxorcist)
the bolt that came with it screwed right on but for some reason the **** wouldnt
since it was only like 15 bucks i decided to force the bitch on. i remembered seeing a craftman tool that was like a rubber strap and you pulled it and it grabed whatever you wanted. after seeing this commercial i thought "now who and the hell needs one of those" well i guess i needed one.
it was like 10 bucks and worked like a charm, i used it right in the sears parkin lot, it took about 5min. good thing i stayed in the parkin lot tho cuz i broke one but since it had a lifetime warrenty i took it back within 10 min of buying it
oh well just thought i would share, thanks for all the suggestions
Buckshot's Avatar
i will try and get them for you
[Modified by Buckshot, 10:05 PM 1/30/2003]
Old Jan 30, 2003 | 06:13 PM
zojirushi's Avatar
are these shift ***** good? just curious. Aren't they freezing cold when u get into your car and the weather is cold? And isn't it too hot to handle when the temps are high?
Old Jan 30, 2003 | 07:57 PM
smdandb2's Avatar
Default Re: just got a fake itr shift **** and... (zojirushi)
Freezing cold, YES!!!!! Thats why I'm using my stocker right now. I'll find out in the summer if the bastard burns my hand.
Its gunmetal, and thats a bad pic.
Old Jan 30, 2003 | 08:17 PM
animated_life's Avatar
Default Re: just got a fake itr shift **** and... (smdandb2)
haha i have that same ****! and YES, during the summer it will burn the living hell out of your hand. which is the whole reason why i'm also using the stocker right now.
