Surge @1500 - 2300RPM
Old Jan 29, 2003 | 06:02 PM
CRX-zila's Avatar
Default Surge @1500 - 2300RPM
90 CRX-dx 1.5L PGM-FI throttle body. Between this rpm range the engine sounds like fuel is being cut-off momentarily. I have changed O2 sensor, checked vacuum lines, timing, plugs and wires. I am leaning to the tps but not really sure. Seems to have to be warmed up before it does this. I also changed the fuel filter but still has the same problem. Was running fine until I got water into the distributor. Had to be towed in. Removed water and drove about 1 week and now this problem. I have also bypassed the cat, but it didn't help either. If I unplug coolant sensor or the tps sensor the problem quits but then I get all of the associated ecu error codes popping up. I am about out of ideas. Could the problem be in the ignitor or distributor somewhere? I would appreciate any suggestions.
Thanks
Old Jan 29, 2003 | 06:08 PM
Cory man's Avatar
Default Re: Surge @1500 - 2300RPM (CRX-zila)
usually a surging idle is the eacv( idle air control valve). Try removing it and cleaning it up a bit. There is a small screen that can get clogged causing this condition. Use some throttle body cleaner and clean the screen. Reinstall it and reset the ecu. Good luck!
Old Jan 29, 2003 | 07:08 PM
poison's Avatar
purge the coolant. make sure there is no air packets/bubbles in the cooling system.
also, make sure tps is set right and functioning, as well as no vacuum leaks at the throttle body.
Old Jan 29, 2003 | 08:20 PM
Desslok's Avatar
Default Re: Surge @1500 - 2300RPM (poison)
If none of the above, check the EGR valve also.
Bustinvtec
May 28, 2006 11:16 PM
pornstartom
Dec 13, 2005 02:09 AM
de_sxc_b20_teg
Oct 4, 2004 04:04 AM
tvrsir
Jun 24, 2004 03:58 AM
Brandon Clifton
Dec 15, 2002 03:21 PM
