timing belts same for gsr and ls?
Old Jan 29, 2003 | 04:30 PM
spettinger's Avatar
Default timing belts same for gsr and ls?
just need to get another opinion, a friends ls vtec runs poorly after replacing the ls timing belt with a gsr belt. compared ls water pump to an ITR water pump, gear looked identical. thanks for the help.
Old Jan 29, 2003 | 04:50 PM
turbohonda's Avatar
Default Re: timing belts same for gsr and ls? (2ndhandCRX)
The LS water pumps and the Gsr water pumps have a different amount of teeth on them. The LS has 19 and the GSR has 22. You need to match the timing belt up with the same waterpump in order for it to work properly.
Old Jan 29, 2003 | 05:08 PM
lazy bum shaughn's Avatar
Default Re: timing belts same for gsr and ls? (turbohonda)
Does the same timing belt run the water pump as it does the motor?
Old Jan 29, 2003 | 09:43 PM
turbohonda's Avatar
Default Re: timing belts same for gsr and ls? (lazy bum shaughn)
On B-series the timing belt runs the cams and the waterpump.
Old Jan 30, 2003 | 02:18 PM
What about D and H series?
Old Jan 30, 2003 | 02:19 PM
sgT's Avatar
sgT
yes to those as well
Old Feb 1, 2003 | 12:49 PM
spettinger's Avatar
Default Re: timing belts same for gsr and ls? (sgT)
i could swear that when i replaced the water pump on a friend's ls vtec, the ITR pump that was supposed to go in had exactly the same tooth count. the mounting was different, so the ls pump went back in with a new seal, as it was in good working order in the first place.
grant97teg
Apr 27, 2009 10:44 AM
shortyz21
Nov 12, 2006 08:38 AM
wpsadmin
Oct 25, 2004 06:09 PM
lsvtechatch04
May 8, 2004 03:20 AM
JR Integra
May 3, 2004 04:17 PM
