4-1 dc header, did you have to cut the cross member
Old Jan 29, 2003 | 04:25 PM
RCautoworks's Avatar
Default 4-1 dc header, did you have to cut the cross member
Did you have to cut the cross member with the u.s version of the 4-1 dc header. I hear some people don't then I hear some people do. So whats the deal ? Aslo if you did, did you cut it or just bang it alittle.
Old Jan 29, 2003 | 04:29 PM
RexB16's Avatar
Default Re: 4-1 dc header, did you have to cut the cross member (90blackcrx)
it depends on what mount kit you have. i had an old school place racing kit that put the motor really close to the front of the car. so to get mine on i had to remove the cross-member and bang it out with a sledge hammer. with newer hasport kits all you have to do its just remove the cross member, put the header on, and then put the cross member back on.
Old Jan 29, 2003 | 04:31 PM
Default Re: 4-1 dc header, did you have to cut the cross member (RexB16)
Why would you have to remove the crossmember, could'nt you just bring it up from the bottom.
Old Jan 29, 2003 | 04:32 PM
ScottEK's Avatar
You cant just feed it up from the bottom.
Old Jan 29, 2003 | 05:00 PM
sparkz's Avatar
Default Re: 4-1 dc header, did you have to cut the cross member (beta13)
I had to cut my crossmember and bang it in a little bit to fit my jdm dc 4-1. should be same for any b series 4-1
bseries with hasport mounts. ground clearance is terrible]
Old Jan 29, 2003 | 05:56 PM
Oval55rag's Avatar
Dude have fun putting that in. If you have a B16 you have to pull the radiator and cross member. Now, you have to cut about 4 inches off the lip of the cross member and then hammer the **** out of it. It took me about 5 times to get it to mount, but it is rubbing the header so it is vibrating the whole car.
Old Jan 29, 2003 | 07:04 PM
Pelican's Avatar
Default Re: 4-1 dc header, did you have to cut the cross member (Oval55rag)
I had to pound the **** outta mine. Hasport and b16 in a CRX
Old Jan 29, 2003 | 07:07 PM
johnzm's Avatar
Default Re: 4-1 dc header, did you have to cut the cross member (Pelican)
i had mine cut and a skidplate isntalled thats welded to the header. its the best thing i coudl have purchased for my JDM 4-1
Old Jan 29, 2003 | 08:37 PM
90Hatch's Avatar
Default Re: 4-1 dc header, did you have to cut the cross member (johnzm)
what do you guys think about a b16 with a c5 block and a dc 4-2-1 clearance on a 90 hatch.. i am sketchin on clearing too.. place racing mounts.. let me know.. and have any of you tried the auto x crossmember.? i need some info..and doesn't banging and cutting the crossmember hurt your hadleing?
Old Jan 29, 2003 | 09:56 PM
Default Re: 4-1 dc header, did you have to cut the cross member (90Hatch)
Why would I need to remove the radiator ? If I need to cut the cross member I will either take it off or do it from the bottom. Any suggestion on what to use to cut it ? Also I understand if I take the crossmember out the radiator might fall so that would be why I need to take it out. Also if I take the cross member off will I need an alignment. I heard yes and no's for this question to.
[Modified by 90blackcrx, 1:04 AM 1/30/2003]
Old Jan 29, 2003 | 10:05 PM
enginetiks's Avatar
You can also pick up a z-10 engineering or place racing crossmember and you will no longer have a clearance problem.
Old Jan 29, 2003 | 10:54 PM
Default Re: 4-1 dc header, did you have to cut the cross member (mschvs)
If I had the extra money I would, but anyways anyone else ? If I can avoid taking the crossmember out that would be great, I was thinking of cutting it with a torch but that would come pretty close to the oil pan. Maybe a saw of some sort ? Any ideas. I wish I had a plasma cutter.
[Modified by 90blackcrx, 2:02 AM 1/30/2003]
Old Jan 29, 2003 | 10:56 PM
CHRIS 1.8's Avatar
I had mine banged with a hammer.
Old Jan 29, 2003 | 11:16 PM
Default Re: 4-1 dc header, did you have to cut the cross member (B16A1-EF8)
Did you bang it with the hammer while it was in the car ?
HxCforever
Feb 6, 2008 12:47 AM
ImportHatch
10
Jul 17, 2003 12:57 PM
acatak
May 13, 2002 05:32 PM
RJL
Dec 10, 2001 04:47 PM
