ARP rod bolts
Old Jan 29, 2003 | 03:36 PM
civichopeful's Avatar
Default ARP rod bolts
I'm building an LS/VTEC and I need the correct part number for a set of ARP rod bolts. I'm not sure if its the 1.6 8mm or the 1.8 9mm set. Thanks
Old Jan 29, 2003 | 03:57 PM
Sonic's Avatar
Default Re: ARP rod bolts (civichopeful)
All b series use the 9mm set, the D series use the 8.
Old Jan 29, 2003 | 04:02 PM
Default Re: ARP rod bolts (Sonic)
Ok Cool. I just wanted to make sure I had the right set. I got conflicting information about which set to use. Thanks
Old Jan 29, 2003 | 06:18 PM
VtecDA9's Avatar
The LS rod bolts are 8mm
Old Jan 29, 2003 | 07:34 PM
non-VTEC's Avatar
if you are using the stock LS rods with you LS/VTEC application you will need the ARP 8mm rod bolts. the package is labled: 1.2-1.6L honda engine's 8mm (or something like that)
the VTEC rod bolts (9mm) will not fit those rods.....
good luck
Old Jan 30, 2003 | 06:09 AM
Default Re: ARP rod bolts (non-VTEC)
Thanks Non-vtec. That is the exact info I was looking for. Now I know I have the wrong set
Old Jan 30, 2003 | 07:24 AM
DLB1994's Avatar
ill buy the set you have if you got 9mm ones
Old Jan 31, 2003 | 05:27 AM
wm5holla's Avatar
Default Re: ARP rod bolts (DLB1994)
WHAT do arps bolts do and what do they look like? pics please!!
Old Jan 31, 2003 | 07:00 AM
Default Re: ARP rod bolts (wm5holla)
http://www.arp-bolts.com/pages/produ.../pro_sers.html
Rod bolts hold the top half of the rod to the bottom half that connects it to the crank. There is a pic on ARPs page.
Old Mar 9, 2003 | 05:37 PM
wm5holla's Avatar
PRice please?
ftp2004
Dec 29, 2004 07:50 AM
boosted k20
Nov 20, 2004 09:23 AM
staticchmbr
Sep 1, 2004 07:16 AM
filtereds0ul
Oct 27, 2003 10:25 AM
tinkerbell
Jul 16, 2002 07:39 PM
