USDM 32 MM AXLES Vs JDM 36MM AXLES.......................***>>>>
Old Jan 29, 2003 | 03:27 PM
TheHater
Guest
Posts: n/a
Default USDM 32 MM AXLES Vs JDM 36MM AXLES.......................***>>>>
Witch ones are better or are they the same performance wise.
Old Jan 29, 2003 | 03:30 PM
-Whitey-'s Avatar
Default Re: USDM 32 MM AXLES Vs JDM 36MM AXLES.......................***>>>> (TheHater)
i would imagine thicker is better(thats what she said) because they would be stronger and safer they would also be heavier bt i doubt it will be noticed
Old Jan 29, 2003 | 03:32 PM
sackdz's Avatar
Default Re: USDM 32 MM AXLES Vs JDM 36MM AXLES.......................***>>>> (FF-Panda)
I vote for 32mm. The opportunity to drop rotational mass doesn't come around too often . Now in a high hp drag car you might need the thicker axles.
Old Jan 29, 2003 | 04:06 PM
function83's Avatar
Default Re: USDM 32 MM AXLES Vs JDM 36MM AXLES.......................***>>>> (sackdz)
i d say 32 cuz 36 would be hard to find replacements if your broke em.
Old Jan 29, 2003 | 04:11 PM
Kid1320's Avatar
Default Re: USDM 32 MM AXLES Vs JDM 36MM AXLES.......................***>>>> (djhatch)
yeah that's the only down fall with my 36mm axles
Old Jan 29, 2003 | 04:46 PM
kenji's Avatar
25 Year Member
Default Re: USDM 32 MM AXLES Vs JDM 36MM AXLES.......................***>>>> (Kid1320)
Can Prelude outer joints be used to replace the '98-up JDM ITR outer joints on the axle?
-kenji
Old Jan 29, 2003 | 05:35 PM
Kid1320's Avatar
Default Re: USDM 32 MM AXLES Vs JDM 36MM AXLES.......................***>>>> (kenji)
i've heard about it and heard it works. i also heard about using 91 accord axles or something like that. but i dont have any personal experiences with it so i dont know for sure
Old Jan 29, 2003 | 05:38 PM
Reid's Avatar
Global Moderator
https://honda-tech.com/zerothread?id=400599
flipkid
Apr 6, 2006 06:00 AM
F20B EG6
Aug 15, 2005 08:39 AM
oem
Jan 27, 2003 08:54 PM
Ehron
Nov 26, 2002 05:04 PM
Kid1320
Nov 24, 2002 04:34 PM
