why not?(b16a subject)
Old Jan 29, 2003 | 02:55 PM
LD_EGSICK's Avatar
Default why not?(b16a subject)
i'm goin to get my jdm b16a motor this week can't i use the stock mounts that came with the motor? doesn't came out of our car in japan too though?
heres a front clip on http://www.nippon-motor.com
Old Jan 29, 2003 | 03:02 PM
RexB16's Avatar
Default Re: why not?(b16a subject) (mysiqu)
no, you can't use the stock mounts. the jdm chassis are slightly different. when you look at the mounts it will be obvious that you will not be able to use them, and thats even if they are still intact.
Old Jan 29, 2003 | 03:31 PM
importfan85's Avatar
Default Re: why not?(b16a subject) (RexB16)
Definitely can't use the stock mounts. Make sure the mounts you get are good quality ones, like the ones from http://www.hasport.com
Old Jan 29, 2003 | 08:40 PM
StorminMatt's Avatar
Actually, most JDM CRXs have the same mounts as USDM CRXs. The exception is the SIR. SIR mounts are ALOT different from JDM SI (ZC equipped) CRX mounts.
Old Jan 29, 2003 | 08:43 PM
WONG FRIED RICE's Avatar
u probably need to get an aftermarket mount kit...
i like the new HAsport ones...they are nice
Old Jan 30, 2003 | 01:05 PM
LD_EGSICK's Avatar
Default Re: why not?(b16a subject) (efzero)
thanks..i was wondering about that.......
Old Jan 30, 2003 | 02:07 PM
usdm_ED7's Avatar
sure you can use them in one of 2 ways.
A: you like having the steering wheel on the wrong side and you have the whole clip welded on.
B: You drill out the welds on the stock SIR mounts and have them welded onto your car with a few other bits and piece to make it whole.
Of course $250 mounts are alot cheaper than both of these.
ya you could git your mounts relocated and welded back on...a few of my frens with EFs have done it...i wish i wouldve dont it when i had the change...no vibration at all while all the aftermarket mounts have alot or a lil vibration i would recommend it to anyone that has the money to do it
Old Jan 30, 2003 | 03:16 PM
LD_EGSICK's Avatar
Default Re: why not?(b16a subject) (usdm_ED7)
welding it..no thanks i rather not go thru all of that casue i'm goin to be swapin it mostly my self...
Old Jan 30, 2003 | 03:20 PM
93eg-EKhybrid's Avatar
How much do one of those front clips go for???
Old Jan 30, 2003 | 03:24 PM
LD_EGSICK's Avatar
Default Re: why not?(b16a subject) (89B16HB)
i'm not gettin the front clip. i was just using the picture as an example about the stock motor mounts in to the usdm engine bay.
Old Jan 30, 2003 | 03:40 PM
EF-9SiR's Avatar
i used the stock b16 mounts. just had to cut and weld. no vibration or anything.
Old Jan 30, 2003 | 06:07 PM
2k1_ITR_0736's Avatar
Default Re: why not?(b16a subject) (crxecution)
i have a set of these that somehow fit into a 89 crx Si. call me crazy, but they bolted right up? maybe i have a JDM chassis? deffintely not? i just got the golden child then huh?
[Modified by 2k1_ITR_0736, 10:08 PM 1/30/2003]
Old Jan 30, 2003 | 06:15 PM
LD_EGSICK's Avatar
Default Re: why not?(b16a subject) (2k1_ITR_0736)
this drive me crazy.......any body got pictures of their set up of mounts>?
Old Jan 31, 2003 | 01:52 AM
I never said you were getting the front clip. I was just wondering if you or anybody else knew how much they go for?
Old Jan 31, 2003 | 06:38 AM
keithv's Avatar
did anybody read StorminMatt's reply???
so if you get the non SIR mounts they will fit in our USDM chassis.
Old Jan 31, 2003 | 06:49 AM
crxgurlllll's Avatar
isnt there like a thread about this every couple of days?
if people would just take time to READ and RESEARCH
Old Jan 31, 2003 | 06:51 AM
Default Re: why not?(b16a subject) (breaka_1_9)
only if you use them along with the non SIR(b series) engine
Old Jan 31, 2003 | 07:00 AM
Slimer89's Avatar
Whats up man, i have the hasport mounts on my set-up. I decided to get them because they are worth it, hassle-free, and bolts right in. I'll take some pics and post them later today.
Old Jan 31, 2003 | 02:11 PM
usdm_ED7's Avatar
cut and weld is the best....its not that expensive either...depends who does it for you....
Old Jan 31, 2003 | 05:29 PM
Mugen Dom's Avatar
ok well i actually have a SiR front clip sitting around here and the mounts are located in different spots slightly and the front crossmemeber is totaly different on the sir it also bolts up completely different so just pay for hasport or hcp mounts makes things alot easier
Old Feb 1, 2003 | 01:49 AM
Default Re: why not?(b16a subject) (JdMB16Ahatch)
How much did you get it for and from where??
lvsdan
25
May 1, 2014 07:51 PM
ej1gsr!
Dec 14, 2011 09:24 PM
FastEg6
May 28, 2009 08:10 AM
Slowass4dr
16
Aug 12, 2005 06:51 PM
td04civic
May 7, 2002 04:56 PM
