rear seat problem
Old Jan 29, 2003 | 02:20 PM
USDMMARK's Avatar
Default rear seat problem
i started the diet for my civic lol, i pulled all the tabs and screws out from my panels in the back, but there is still the main bolt that is holding the seat in, i seen where i have to loosen it, but i was wondering if anyone found an easier route, (ex. tool or way to get to it), there is a little housing over top of the bolt, with a slot, that makes it hard to get the wrench in there, if anyone has taken a seat out of a hatch, and knows how to get to that damn bolt im me or something please,
thanks
Old Jan 29, 2003 | 02:41 PM
BeaverAzz's Avatar
Default Re: rear seat problem (SLOMO-HATCH)
first, fold the upper part of the seat down.you should be able to push the upper pieces together and pull them out. the carpet that covers your spare tire is attached to the bach of the these two pieces. when have this out you should be able to see the bolt that is holding down the bottem part of your seat!!
Old Jan 29, 2003 | 02:51 PM
USDMMARK's Avatar
Default Re: rear seat problem (BeaverAzz)
dude i never unbolted my top part, it has to be bolted in there some how, i just have all the plastic unbolted, that's all, there is two bolts in there, one on each side inside of a steel housing that i cant seem to get too, i need to get the top part off first but i don't know where to start
please help
Old Jan 29, 2003 | 02:59 PM
BeaverAzz's Avatar
look on top of the back seat rest there are two black tabs sticking up (ome on each side) pull them you will be able to fold the seats down then look down you'll see a black plastic c-clip. pull this out. then pull your seat out
Old Jan 29, 2003 | 03:09 PM
USDMMARK's Avatar
well bro i know its dark out and ****, but i can't get it out, on the sides there are two bolts running through the seats, through the housing and a nut on the other side, i did pull the two black c clips off of these bolts earlier, i can't seem to get this mother fu**er out,
Old Jan 29, 2003 | 03:24 PM
eh2_b20z's Avatar
Dude it's easy
1) Fold the seats down
2) Look between the seat and the plastic interior and remove the plastic clips around the bar connecting them to the interior.
3) Move the seat into the side and pull the center part of the seat out.
4) If the seats are not out of your car, you need to sell it and drive something else.
EZ$$EF
Sep 17, 2008 12:17 PM
jgrif08
Oct 23, 2006 06:08 PM
1hotintegra
Acura TL, RL & ZDX
Apr 14, 2005 02:13 AM
Powered By Garrett
Mar 26, 2005 08:29 PM
D114
Sep 29, 2003 05:01 AM
