Ultra L Aluminum Flywheel (8 lbs.) question
Guest
Posts: n/a
Ultra L Aluminum Flywheel (8 lbs.) (88-89 only) 060610300 is what im thinking about purchacing for my 88 hatch. however, 88s have 21 splines, 89 has 20. im under the impression that this will no work then?
The splines are on the clutch disk, not the flywheel if that answers your question. Basiclyyou are limited to the pressure plate size you have now as that was the only year that used that spline count. but then there are better aftermarket disks to be had. 90-91 had a larger diameter clutch, the difference between the 88 and 89 was the clutch disk itself, both used the same flywheel and pressure plate.
[Modified by virginia_dude, 2:45 PM 1/29/2003]
Since your upgrading your clutch setup, Why not go with a 90-01 setup so you get the bigger disk. 88's are 190mm and 90-91 are 212mm. ACT makes a disk that is 212mm with the correct spline for the 88 input shaft. I have an 88 tranny in my car and it works awesome.
Guest
Posts: n/a
anything is better than my current setup which allow me to use all of 13% throttle before it slips since i broke the pressure plate
Wish I had soemthing better than a New Borg-Warner POS. Damn thing slips when pushed real hard. ANd I don't have the stickiest tires in the world either. 205/50-15, damg thing has done that for most of the last year too, even though I babied it the first 1,000 miles when it went in. Knew I should have spent the extra money and got something decent, but NO! I had to listen to my wife. And the ZC is overpowering the 212mm clutch the ZC flywheel takes.
[Modified by virginia_dude, 3:46 PM 1/29/2003]
[Modified by virginia_dude, 3:47 PM 1/29/2003]
Guest
Posts: n/a
the knock off oems have worked fine on my d15.... they only last 20K tho =P **** broke b/c the throw out berring poped of one side of the spring and i drove it like that for a week as i couldnt do anything about it at the time. im prolly going to buy a new fork and spring to prevent this from happening in the future.
i envy your 205's... im on 155 75 13
Well the 130HP of the ZC is a bit more than the 92hp of a DX. And the slipping does occure only at shifts made above 6,500RPM. Well sometimes it grabs and I get tirespin other times the clutch slips. Its that close to being a fine clutch. Close but no cigar.
Super79Dave
Jan 24, 2007 03:48 PM
omgwtfbbqcrx
Apr 15, 2006 12:50 PM
methanemotorworks
Feb 13, 2006 07:32 PM
