is a different size timing belt needed when going from a CX head to DX?
Old Jan 29, 2003 | 10:13 AM
civicracer1993's Avatar
Default is a different size timing belt needed when going from a CX head to DX?
im goin from a d15b8 to d15b7 head .. i tried to use a 96 VTEC EX head but my timing belt was too big.. will my same belt work for the 92-95 DX head?
mike'
Old Jan 29, 2003 | 10:15 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: is a different size timing belt needed when going from a CX head to DX? (civicracer1993)
I believe when you swap on a vtec head, you'll need to use the VX timing belt. The DX heads should take the same timing belt. Don't quote me, but I'm almost positive.
Old Jan 29, 2003 | 10:58 AM
nsxmatt's Avatar
The dx head will work with your current belt and the VX belt will be the one to use for a vtec head. If the head is off check and see if your CX had valve reliefs for 16 valves. Since the cx is a 8 valve motor some of them came with reliefs for 8 valves only which would mean a big mess if you put a dx or vtec head on it.
theclutchpoppa
Mar 7, 2003 03:58 PM
Biglooney2
Mar 2, 2003 06:47 PM
J T*
Aug 13, 2002 05:08 AM
J T*
Aug 6, 2002 07:33 PM
