Heater Controls don't work any more...
Old Jan 29, 2003 | 07:23 AM
nautica_t's Avatar
Default Heater Control lights don't work no more...
I was putting a VTEC light right where the a/c button is located for those who didn't have a/c on there vehcile their's a black piece where the button goes so i decided to put my vtec light there. and now the top row of lights don't work. the bottom do however. can anybody tell me what could've happened???
the lights that don't work are the top row. the row at which you set how high the settigns you wish to set at for the fan speed. and the re-circulation of air goes.
i have no lights up there. and i don't knwo why, but i do have it on the bottom row. not the top, can anyone tell me what's wrong.
TIA
[Modified by nautica_t, 4:31 PM 1/29/2003]
Old Jan 30, 2003 | 05:45 AM
keithv's Avatar
Default Re: Heater Control lights don't work no more... (nautica_t)
maybe the blubs are blow out and it was a coicedence that it happened around the same time you put your vtec light in...
Old Jan 30, 2003 | 06:47 AM
WuShu's Avatar
New User
Default Re: Heater Control lights don't work no more... (breaka_1_9)
if you find the answer to the problem please give us all an asnwer. This is a big problem ive seen with pretty much all 4th gens, those little bulbs love to die out. My guess its the contact points, my **** has never worked, but the lights will turn on occasionally, the number lighting is the same way, i fiddle with it one day and since they have never worked.
Old Jan 30, 2003 | 07:00 AM
nautica_t's Avatar
Default Re: Heater Control lights don't work no more... (HondaCRX)
i guess i'll wait until the summer than
its freezing up in canada!!
i can't work on my car for long otherwise my toe's get numb
but if i do find out, i will definitely inform everybody.
Old Jan 30, 2003 | 08:07 AM
incubus's Avatar
i have a similar problem as well.
Old Jan 30, 2003 | 08:15 AM
nautica_t's Avatar
Default Re: Heater Control lights don't work no more... (incubus)
if all else fails i'm going to buy one of those dancing bass lights and just shove it in the back and have constantly on, instead of it beating.
so that way it will emit a blue out of the guages.
that's what happen with my cluster guages. i have no lights so i have blue lights shining inside my gauge and it looks sweeeeeeeeeeeettt...
espicaly since the needles emit a neon blue and the white turns up bluish. looks like reverse indiglo guages at half the cost and less modification.
-> but too bad nobody has ever fixed this problem before.
Old Jan 30, 2003 | 02:11 PM
annonymous_ef_owner's Avatar
there must be a corruption or a loose wire, check that out, if not then they are definetly your bulbs and you can't buy those anywhere not even Honda, you must go to a junk yard to grab a set if there still good. Good luck
AznBlueBoy
Aug 9, 2010 10:29 PM
em2power
Honda Civic (2001 - 2005)
Jan 5, 2008 07:17 PM
MeekalLS
Audio / Security / Video
Jul 12, 2006 02:14 PM
Metal Honda G
Sep 21, 2004 04:58 PM
