I need a gauge cluster pinout for a 5th gen......
Old Jan 29, 2003 | 01:19 AM
G-MO's Avatar
Default I need a gauge cluster pinout for a 5th gen......
Need one to get my project finished. Can anyone help me out?
Old Jan 29, 2003 | 08:28 AM
nickg11111's Avatar
Default Re: I need a gauge cluster pinout for a 5th gen...... (G-MO)
best i could do is for a 4th gen. let me know if you want that, the wiring in both cars is mostly identical. also, for which harness (on mine there are three in the gauge cluster). what wires are you trying to find, and what are you trying to do (there may be an easier solution).
Old Feb 8, 2003 | 10:31 AM
G-MO's Avatar
Default Re: I need a gauge cluster pinout for a 5th gen...... (nickg11111)
anyone else?
Old Feb 8, 2003 | 04:05 PM
carolinaACCORD's Avatar
what do you need it for? i can post it for you, but which harness do you need?
Old Feb 8, 2003 | 09:31 PM
G-MO's Avatar
Default Re: I need a gauge cluster pinout for a 5th gen...... (carolinaACCORD)
I need it for the three green plugs on the gauge cluster
Old Feb 8, 2003 | 10:16 PM
ratherbewalking's Avatar
anyone have a pin puller? where do i get one? i really dont wanna rip pins out with pliers. im swapping an ex in my lx and need to add vtec wires, but i wanna use my harness for the wires and just flip flop the ones im not using
Old Feb 9, 2003 | 06:32 AM
jweller's Avatar
Default Re: I need a gauge cluster pinout for a 5th gen...... (ratherbewalking)
try radio shack for the pin puller
Old Feb 9, 2003 | 07:25 AM
Default Re: I need a gauge cluster pinout for a 5th gen...... (jweller)
thanks
Old Feb 9, 2003 | 04:41 PM
yes RadioShack has the pin extractor. i will post the pinout, but ill have to wait till I go to work tomorrow to scan it.
Old Feb 10, 2003 | 09:26 AM
G-MO's Avatar
thanks
Old Feb 10, 2003 | 06:57 PM
ok, here's what i came up with. still haven't had a chance to scan it yet.
the first column is pin #, the second column is wire color, the third column is cluster light or circuit, the last column is pin # signal source.
***g/t stands for goes to***
***C13, C14, C16, C6 go to PCM also (auto)***
<U>Connector "A" is the 14-P connector </U>
A1---&gt;blu/red---&gt;brake check circuit---&gt;g/t #9 fuse (7.5A)
A2---&gt;orn/wht---&gt;comes from high beam indicator light---&gt;g/t dimmer relay
A3---&gt;red/yel---&gt;high beam indicator light---&gt;g/t #19 fuse (20A)
A4---&gt;lt. grn/red---&gt;malfunction indicator light---&gt;g/t ECM/PCM
A5---&gt;yel---&gt;power---&gt;g/t #1 fuse (10A)
A6---&gt;NOT USED OR CANT IDENTIFY
A7---&gt;grn/blu---&gt;left turn signal light---&gt;g/t left turn signal switch
A8---&gt;grn/red---&gt;brake system light---&gt;g/t parking brake switch
A9---&gt;blk---&gt;ground
A10---&gt;red/blu---&gt;seat belt reminder light---&gt;g/t driver's seat belt switch
A11---&gt;grn/yel---&gt;right turn signal light---&gt;g/t right turn signal switch
A12---&gt;blu---&gt;srs indicator circuit and srs indicator light---&gt;g/t srs unit
A13---&gt;NOT USED OR CANT IDENTIFY
A14---&gt;NOT USED OR CANT IDENTIFY
<U>Connector "B" is the 22-P connector</U>
B1---&gt;blk/wht---&gt;power for safety indicator circuit---&gt;g/t ceiling light circuit
B2---&gt;grn/wht---&gt;right rear door indicator light---&gt;g/t right rear door switch (sdn)
B3---&gt;grn/red---&gt;front pass. door indicator light---&gt;g/t front pass.door switch
B4---&gt;orn---&gt;trunk indicator light---&gt;g/t trunk latch switch
B5---&gt;grn/orn---&gt;driver door indicator light---&gt;g/t driver door switch
B6---&gt;yel---&gt;power---&gt;g/t #1 fuse (10A)
B7---&gt;red---&gt;gauge lights---&gt;g/t dash lights brightness control
B8---&gt;red/blk---&gt;gauge lights and C.C. circuit---&gt;g/t combo light switch
B9---&gt;yel/grn---&gt;ECT gauge---&gt; g/t engine coolant temp. sensor
B10---&gt;blk---&gt;ground
B11---&gt;NOT USED OR CANT IDENTIFY
B12---&gt;tachometer drive circuit (tach)---&gt;g/t ignition control module'
B13---&gt;wht/grn---&gt;safety indicator ciruit board---&gt;g/t left taillight failure sensor
B14---&gt;grn/yel---&gt;left rear door indicator light---&gt;g/t left rear door switch (sdn)
B15---&gt;NOT USED OR CANT IDENTIFY
B16---&gt;NOT USED OR CANT IDENTIFY
B17---&gt;NOT USED OR CANT IDENTIFY
B18---&gt;yel---&gt;daytime running lights indicator---&gt;g/t #1 fuse (10A)
B19---&gt;yel/red---&gt;oil press. indicator light---&gt;g/t engine oil pressure switch
B20---&gt;wht/blu---&gt;charging sytem light---&gt;g/t alternator
B21---&gt;blu/wht---&gt;daytime running lights indicator light---&gt;g/t drl control unit
B22---&gt;charging system light---&gt;g/t #4 fuse (7.5A)
<U>Connector "C" is the 16-P connector </U>
C1---&gt;yel/blu---&gt;fuel gauge---&gt;g/t fuel unit
C2---&gt;lt. grn/red---&gt;low fuel indicator light---&gt;g/t fuel unit
C3---&gt;blu/red---&gt;D4 indicator light---&gt;g/t PCM (auto)
C4---&gt;NOT USED OR CANT IDENTIFY
C5---&gt;grn/wht---&gt;"P" indicator light---&gt;g/t A/T gear position switch (auto)
C6---&gt;grn/red---&gt;"R" indicator light---&gt;g/t A/T gear position switch & PCM (auto)
C7---&gt;grn---&gt;"N" position indicator---&gt;g/t A/T gear position switch (auto)
C8---&gt;NOT USED OR CANT IDENTIFY
C9---&gt;blu/wht---&gt;abs indicator light---&gt;g/t abs control unit
C10---&gt;NOT USED OR CANT IDENTIFY
C11---&gt;blu/blk---&gt;cruise indicator light---&gt;g/t cruise control unit
C12---&gt;orn---&gt;speedo/odo/trip meter drive circuit---&gt;g/t VSS & ECM & C.C. unit
C13---&gt;lt. grn/wht---&gt;"1" position indicator---&gt;A/T gear position switch (auto)
C14---&gt;grn/yel---&gt;"2" position indicator---&gt;g/t A/T gear position switch (auto)
C15---&gt;lt. grn---&gt;C5 & C7---&gt;g/t PCM (auto)
C16---&gt;grn/blu---&gt;"D3" position indicator---&gt;g/t A/T gear posion switch (auto)
[Modified by carolinaACCORD, 10:58 PM 2/10/2003]
Old Feb 11, 2003 | 07:42 AM
also, the wagon models have a little bit different pinout.
[Modified by carolinaACCORD, 11:42 AM 2/11/2003]
Old Feb 11, 2003 | 07:46 AM
hater_04's Avatar
you could buy one duh..
wsiracerz
Oct 18, 2004 08:36 PM
00TypeSH
Jan 28, 2003 06:24 AM
Greg L
Aug 8, 2002 05:32 PM
pr0digy1
Feb 11, 2002 12:17 PM
