88-89 Sidemarkers
Old Jan 28, 2003 | 10:06 PM
Kato7997's Avatar
Default 88-89 Sidemarkers
How in the hell do u remove the 88-89 Sidemarkers/corners?? It looks like to me, you have to remove the whole headlight assembly...
Old Jan 29, 2003 | 05:16 AM
Hondasaurs's Avatar
Default Re: 88-89 Sidemarkers (Kato7997)
There are two screws on it. Take them out then carefully pry it out. There are plastic slides that hold it in place.
Old Jan 29, 2003 | 05:29 AM
Superhatch's Avatar
Default Re: 88-89 Sidemarkers (ZC_CRX)
-Jake
Old Jan 29, 2003 | 06:45 AM
spun Vtec's Avatar
Default Re: 88-89 Sidemarkers (Superhatch)
ignor this its the 90-91 usdm..
take the 2 screw's out and hit the light with your hand lightly...pushing tward the front of the car it may take 5 or so hit's for them to come out but you have to do this because ther are slider's that have to come out of a slot.]
-larry
Old Jan 29, 2003 | 02:13 PM
Kato7997's Avatar
That looks like the 90-91 corner, the brackets are different...
Old Jan 29, 2003 | 02:33 PM
No More Civic's Avatar
Nope, those are 88-89 corners. The 90-91 didn't have the screws on the outside of the corners that i circled.
Old Jan 29, 2003 | 02:42 PM
LD_EGSICK's Avatar
did u even try to remove it?
Old Jan 29, 2003 | 04:12 PM
Kato7997's Avatar
Default Re: 88-89 Sidemarkers (SlowCivicDX)
Mine don't look like that, they do have the two screws on the outside, but on the back of the corner assembly there are to clips that clip into the headlight assembly...they are not at all easy to get out...
Old Jan 31, 2003 | 02:32 PM
eccentric.ek's Avatar
just pull it out its easy!!
Old Jan 31, 2003 | 04:08 PM
Kato7997's Avatar
Default Re: 88-89 Sidemarkers (redUSDMhb)
I swear I'm not retarded, maybe mine are just jacked up...
Old Jan 31, 2003 | 09:00 PM
TheBestCRX's Avatar
u just gotta slide them out. yeah, mine were stuck in there pretty good and i actually snapped the sliders off of one of my corners when i took them out. you really just gotta pull them out, after you got the screws out.
Old Feb 1, 2003 | 02:25 AM
Snapshift's Avatar
Remove the screws, shoot WD 40 around the housing. Try to masage the corners free they eventually come.
LoneAutosport
11
Dec 21, 2007 11:31 AM
DaCRXboi
31
May 14, 2006 12:20 AM
sleeperteg
Aug 17, 2005 08:38 AM
psicrxsi
Jul 1, 2003 10:38 PM
NikoZai
Jul 9, 2002 02:41 PM
