Coilovers vs Springs
Old Jan 28, 2003 | 09:14 PM
GetawayInMoscow's Avatar
Default Coilovers vs Springs
I remember a while ago there was a post on ClubSi debating the two. It basically said that coilevers were not good for handling because they threw off the corner weight of the car. The article said springs were the only way to really improve handling on your car and pretty much that coilover systems like skunk2 and ground control were complete garbage.
Is this correct? Maybe I should be posting in the Road Racing forum however I figured maybe shawnhayes could add in his 2 cents here on what the real deal is. It seems as if a lot more people use coilovers as apposed to lowering springs.
I know there has been similar posts in the past, but can anyone touch base on this corner weight thing as well as other factors to take into consideration for better handling?
Old Jan 28, 2003 | 09:16 PM
jonas's Avatar
Default Re: Coilovers vs Springs (GetawayinMoscow)
skunk2 and ground control are NOT coil overs. they are sleeves
Old Jan 28, 2003 | 09:21 PM
abraunworth's Avatar
New User
Default Re: Coilovers vs Springs (jonas)
If you are going to get coilovers, you need to get the real thing, not just the sleeves.
But either way, coilovers increase handling as far as I have seen. My friend put coilover sleeves o his 88 GTI wheras he used to have Neuspeed springs. it handles a lot better. Granted it doesn't have independant rear suspension. Don't really know how much difference that will maake.
Don't see any reason springs would handle any better, coilovers for the most part are stiffer, soooo....
Old Jan 28, 2003 | 09:27 PM
FifthGearOnline's Avatar
Default Re: Coilovers vs Springs (abraunworth)
sounds like club si logic to me
Old Jan 28, 2003 | 09:28 PM
Street Ghost's Avatar
i heard that coilovers are a racing setup, so i believe they should handle better than springs. auto-x drivers use coilovers because they are stiffer = minimize body roll. springs give a more comfy ride tho. i have ground control coilover sleeves, and personally, i like them. they handle great.
Old Jan 28, 2003 | 09:29 PM
Default Re: Coilovers vs Springs (FifthGearOnline)
You don't know anything about suspension.
Please prove my statement wrong.
Old Jan 28, 2003 | 09:34 PM
Mike_C's Avatar
lmao. a properly setup set of coilovers will destroy any springs, any day.
edit: you do realize springs do nothing for damping or rebound correct? with some high-rate springs on your car you'll just bounce around all day.
[Modified by JMU1337v0.2, 1:34 AM 1/29/2003]
Old Jan 28, 2003 | 09:38 PM
Ministry's Avatar
Default Re: Coilovers vs Springs (JMU1337v0.2)
Im confused. Are you really asking if custom springs on stock shocks handle better than a set of full coilovers?
thats ridiculous
[Modified by dreamer, 6:38 AM 1/29/2003]
Old Jan 28, 2003 | 09:57 PM
VtecBio009's Avatar
Default Re: Coilovers vs Springs (dreamer)
word, i have Neuspeed Coilovers on my 00 Si and I can corner in some intersections without having to brake going 40mph+.
but thats IF its clear to go
Old Jan 28, 2003 | 10:07 PM
XxDemonxX's Avatar
Default Re: Coilovers vs Springs (VtecBio009)
dont coilovers have springs on them?
Old Jan 29, 2003 | 11:11 AM
cp_harrington's Avatar
Default Re: Coilovers vs Springs (XxDemonxX)
I installed a set of ebach springs their ok but they bounce arround alot. my boy has a 93 ex and has a set of coil overs (dont know the makers) and his suspension is a he!! alot stiffer than mine I'm going with coil overs this weekend! matched up with the proper shoks & struts you'll handel like a dream!
Old Jan 29, 2003 | 11:18 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: Coilovers vs Springs (cp_harrington)
i believe he is asking if a spring setup (Like Neuspeed springs or Eibach) is better the a sleeve and spring (Given the term Coilovers even thought they are just a sleeve and spring) setup.
The answer is just springs alone on either setup isn't that great. Corner weighting without adjustable struts as well isn't going to do much.
The only way Ican see springs being better then struts is if someone doesn't set the height of the sleeve properly and has their car sitting @ 4 different ride heights @ four different corners of the suspension. That's not the sleeve/spring setup......that's a dumb ***.
I have yet to see a foolproof way to set a car up with an adjustable sleeve/spring combo or true coilovers unless they go to a shop that can setup ride height (esp with you in the car).
Just my 5 cents.
Old Jan 29, 2003 | 11:20 AM
96 SOHC VTEC's Avatar
Default Re: Coilovers vs Springs (Apex i ITR)
I have Ground Control coilovers and Koni Yellows on my car, and you could have fooled me, but I think it handles great.
Old Jan 29, 2003 | 11:28 AM
93civEJ1's Avatar
everyone I hear hates sleeves, personally i run skunk2 springs , not sleeves
Old Jan 29, 2003 | 11:46 AM
Apex i ITR's Avatar
Default Re: Coilovers vs Springs (93civEJ1)
Sleeves and adjustable struts are good compromise but the poster needs to be a little more clear.
And I said it was hard to get the proper height with adjustable Sleeve's or coilovers....not impossible. Even when you'd think its set right sometimes its not.
Old Jan 29, 2003 | 04:39 PM
Sorry for the confusion. I was talking about the fake coilovers where you just have a sleave in a shock. I wasnt talking about the real deal because I know about those. But from what I am reading both sleeves and and springs are equally crappy?
Old Jan 29, 2003 | 04:50 PM
black2kcivic's Avatar
nope, I have Koni yellows and eibach ERS springs with a 450 spring rate up front and a 500 spring rate in the rear and my car owns some corners now. For the amount of money I paid you would be hard pressed to find an equally good set up for less. and Im sure that you would not have an easy time finding one that costs more. I personally prefer coilovers over springs and the reason is adjustability and the quality of the ride. The ride on non-adjustable springs is no where near what my car is, nor is the handling.
crazyowes2000
Suspension & Brakes
59
Jun 28, 2011 10:47 AM
scatuli
Apr 3, 2004 01:55 AM
MooreBoost
Jul 22, 2003 09:45 AM
JDM_ITR
Jul 19, 2002 06:57 AM
DRxCIVIC
11
Apr 22, 2002 09:33 PM
