any recalls or problems with 4th gen accords?
Old Jan 28, 2003 | 06:49 PM
hoysum_dimsum
Guest
Posts: n/a
Default any recalls or problems with 4th gen accords?
were there problems or recalls with 4th gen accords? i know stuff like rust on quarter b/c of the rubber...what else like machnically and etc. starter i know to or is it called alternator.
Old Jan 28, 2003 | 07:16 PM
RaceTilIDie's Avatar
Default Re: any recalls or problems with 4th gen accords? (hoysum_dimsum)
Distributor including igniter. Front seals. Auto Tranny rough shifting. That's pretty much all I've seen Honda admit to.
EDit- those weren't recalls, just "problems they took care of at no charge"
[Modified by RaceTilIDie, 4:17 AM 1/29/2003]
Old Jan 28, 2003 | 11:02 PM
briq4's Avatar
Default Re: any recalls or problems with 4th gen accords? (RaceTilIDie)
One annoying recurring problem is that the heater control **** keeps breaking, good to keep a spare one so you don't have to swap the fan control **** back and forth once the **** finally brakes. My alternator lasted 150,000 miles and only went bad due to the dealer tightening the belt too much and it wore out the bearings. I had to have the Clutch master cylinder replaced it was leaking. I had the distributor seize (replaced for free). and I think it was a leaky cam seal, it was leaking since I got the car with 36,000 miles on it and then around 220,000 the drip finally made it to the ground. I'm at 254,000 miles now and still running well.
[Modified by briq4, 3:03 AM 1/29/2003]
Old Jan 28, 2003 | 11:19 PM
Starrman85's Avatar
Default Re: any recalls or problems with 4th gen accords? (briq4)
as far as the rough shifting with the auto...i dont think theres any fix for that. distributor...honda fixed that for free??? when did that free fix end? i had to get that replaced last summer at around 68k miles, i only have 74k on my 92 accord...i wonder if honda would cover the bill if i can find a reciept. o well
Old Jan 28, 2003 | 11:26 PM
briq4's Avatar
Default Re: any recalls or problems with 4th gen accords? (STARRMAN85)
it was probably 4 or 5 years ago, and I had 90K at the time. Sorry read that wrong I don't know if there was a time limit or just a mileage limit?
[Modified by briq4, 3:27 AM 1/29/2003]
Old Jan 29, 2003 | 04:42 AM
RUBZERK's Avatar
http://WWW.autorecalls.COM
Old Jan 29, 2003 | 05:22 AM
Baltz's Avatar
Default Re: any recalls or problems with 4th gen accords? (RUBZERK)
Yeah something definately needs to done about the auto tranny cause mine lets you know its shifting...its rough..very rough...oh well
Old Jan 29, 2003 | 05:53 AM
Desslok's Avatar
Default Re: any recalls or problems with 4th gen accords? (4th gen accord)
I changed mine twice with Mobil 1 Synthetic ATF and it's a little smoother. Any improvement is better than stock though.
Old Jan 29, 2003 | 07:45 AM
Baltz's Avatar
Default Re: any recalls or problems with 4th gen accords? (Unexplained 98 percent)
I'll definately have to change it and see if this works...maybe buy a Helms so I can see where everything is at unless someone on here can scan in the pages from the Helms for a 4th gen lx coupe accord with an auto tranny that would be much appreciated
Old Jan 29, 2003 | 10:02 AM
hoysum_dimsum
Guest
Posts: n/a
wow thx....all these problems has already happened to me....the switch for the heat/ac, the distrubitor..also cap and rotor, the auto shifting is tough until replace oil, and etc. my car now has warm heat instead of hot and the temp goes down when ever i drive it for about 5min. this happened after i got my water pump, time belt, distributor, bal shaft, fixed. i also had to replace motor for the auto window on driver side b/c it went sideways...i think b/c it froozed over the winter and i was attempting to use it to clear off the snow. thx for the imput everyone.
i spent about 1500 the past yr fixing my car
Old Jan 29, 2003 | 10:32 AM
briq4's Avatar
Hoysum how many miles do you have on your accord? Just out of curiosity.
Old Feb 9, 2003 | 05:09 PM
hoysum_dimsum
Guest
Posts: n/a
115,000. sorry for late reply.
sandiegan
Oct 18, 2008 10:57 AM
ItalynStylion
Sep 7, 2004 04:55 AM
illycut
Apr 18, 2004 11:13 PM
Jet Black
Dec 29, 2003 05:33 AM
kotetu
Sep 18, 2003 11:28 AM
