What is a leakdown test?
Old Jan 28, 2003 | 06:46 PM
lazy bum shaughn's Avatar
Default What is a leakdown test?
What exactly is a leakdown test? How is it better than a compression test?
Thanks my wonderful Honda-tech brothas.
Old Jan 28, 2003 | 06:50 PM
b19coupe's Avatar
Default Re: What is a leakdown test? (lazy bum shaughn)
In a leakdown test, you pressurize the cylinder using compressed air with the valves closed. The leakdown tester gives you a reading, usually in percentage, of what that particular cylinder is leaking.
Old Jan 28, 2003 | 06:51 PM
Default Re: What is a leakdown test? (b19coupe)
Just wondering, how does a cylinder leak? How do you get percentages on the cylinders, what kind of gauge shows it?
Old Jan 28, 2003 | 07:00 PM
RaceTilIDie's Avatar
Here's the one I use: http://buy.snapon.com/catalog/pro_de...re&dir=catalog
Old Jan 28, 2003 | 07:55 PM
StorminMatt's Avatar
A leakdown tester is a device that connects to a compressor and the spark plug hole in the cylinder. In order to leak down test a cylinder, you connect the tester to a cylinder that is at TDC in the compression stroke. The tester applies pressure from the compressor to the cylinder. A gauge then measures how much air is flowing from the compressor to the cylinder (the less air, the better), and the amount of leakdown is meaured in percent. Lower is better. While this is happening, you can then find where the engine is leaking based on where the air is going. Air going out the valves indicates valves that are not sealing. Air going into the crankcase indicates bad rings. Air going into adjacent cylinders indicates a bad head gasket. And air going into water jackets indicates a bad head gasket, cracked cylinder and/or head, or a warped cylinder and/or head. A leakdown test is not necessarily better than a compression test in that it can detect problems where a compression test indicates no problems. But it can tell you exactly WHAT is bad when compression is low. For this reason, a leakdown test is generally used to complement a compression test rather than replacing it.
[Modified by StorminMatt, 4:56 AM 1/29/2003]
negusjuda
Aug 8, 2011 02:44 PM
flipldls
Nov 28, 2010 04:41 PM
silverEH2
Oct 14, 2003 11:54 AM
jeremy.
Sep 26, 2003 09:03 AM
1fstevo
Mar 25, 2002 03:52 AM
