Spark Plug Arrangement on Distributor
Old Jan 28, 2003 | 04:42 PM
Kg cm2's Avatar
Default Spark Plug Arrangement on Distributor
I have a 92 Hatchback VX model, with a 1.5 liter non-vtec engine. No modifications. I recently replaced the distributor and must have mixed up the arrangement of how the spark plug wires go back onto the cap. So, 3 questions;
What is the firing order for the cylinders?
What is the arrangement of spark plug wires onto the distributor cap?
Are there any websites that would provide a diagram to go along with your answers?
Now, I have already searched this topic and founf many conflicting opinions. So, please, ONLY POST ANSWERS IF YOU KNOW THEM FOR SURE. I do not want to sound rude, it's just I need factual information, not "I think" or "it should be". Thank you guys very much.
Old Jan 28, 2003 | 05:15 PM
mugenracer's Avatar
Default Re: Spark Plug Arrangement on Distributor (Kg cm2)
dont know if this is correct ofor your car but this is the arrangement on my B18C
2 - 3
1 - 4
as you look at the side of the distributor standing at the front passenger side wheel, #1 wire is bottom left, 2 top left, 3 top right 4 bottom right.
cylinders are numbered 4-3-2-1 from the distributor side towards the drivers side, so the bottom left plug wire (longest) goes to the furthest cylinder
Old Jan 28, 2003 | 07:12 PM
Kg cm2's Avatar
Default Re: Spark Plug Arrangement on Distributor (mugenracer)
Anybody else? Perhaps somebody with my exact motor or the knowledge on my exact motor? Is this right, or if not, what is?
Mugenracer-that may be right, but I just want to be sure that it is the same. Thank you for the answer, I just want to see if others know if they are the same.
Old Jan 28, 2003 | 07:53 PM
IN VTEC's Avatar
The firing order is 1-3-4-2. The motor rotates CCW (viewed from the crank pulley side). So, if you look at it from the distributor side, the distributor rotor rotates CW.
#1 cylinder fire is the bottom left.
x-y
1-z
3-4
1-2
Old Jan 28, 2003 | 09:08 PM
Kg cm2's Avatar
Default Re: Spark Plug Arrangement on Distributor (IN VTEC)
Thank you very much for the response so fast. Tomorrow, wen the sun is out, hopefully, I will be arranging in this order and hopefully getting the car running again. Once again, I appreciate this heavily.
zc_crx
Jan 4, 2006 04:06 PM
Honda_18
Nov 27, 2004 10:07 AM
SunkistRex
Mar 14, 2004 08:06 AM
