What Valve springs and cam recommended for turbo?
On GSR motor..
Please recommend what valve springs and cam is recommended if I wanted
to go with an aggressive high rpm cam (like ITR cams) and turbo?
Oh and while im at it...
Where do i get the least expensive jdm front end?
Not interested in the bumper or any of that I plan on having a mugen bodykit.
Thanks.
Thanks.
uhhh agressive high overlap cams and turbos don't usually mix very well. Your'e stock GSR valvetrain should be fine... spend the $$ elsewhere (like on some forged pistons - your'e gonna need em eventually
On GSR motor..
Big cams (like an ITR) may just add to the blow-through effect w/o any increase in performance, and may even degrade performance at higher boost levels.
Thanks.
Thanks.
Make up your mind.
Springs not need unless you need to rev higher. ITR cams have more duration than GSRs. The answer as to which has more potential is still debated.
Mugen front is JDM only so you have to convert to jdm before you put the mugen front end on. I dont need the bumper only the conversion kit.
Sorry, should have been more literal. I just assumed ppl would understand what
I meant.
I meant.
ah.. hehe no kidding lol.
Okay so regardless of better off sticking with stock valve train and all that..
Lets talk hypothetically here.
Say I wanted a turbochareged GSR motor that revs to 8400 without blowing up.
What do I need to do?
[Modified by 8400RPMS, 7:41 PM 1/28/2003]
change to ITR valvesprings if your'e really worried about it - but you shouldn't have to rev that high to make power on a boosted motor - you need to do a search - I'm sure this has been covered before.
If you want to actually turn up the boost on the motor, resleeve the block, add block guard, forged pistons, I beam rods, ARP head studs, it should hold together.
sorry about the big pics.
Ed
shiftgear8000
Dec 10, 2004 08:48 AM
respectblades
Dec 29, 2003 05:27 PM
