can i use this wiring harness?
ok, i have my whole b17 package with everything. and what i'm wondering is should i just use the wiring harness that came with the b17 or my Si wiring harness. the harness for the b17 is totally complete. and what problems would i have using the b17 harness. btw, i will be using the gsr p61 ecu, and everything i need for the swap is there besides mounts.(at least i hope) oh yeah, i plan on running OBD1 of course.
thanks guys, isaac.
[Modified by 88CRXSiB17, 2:01 AM 1/28/2003]
thanks guys, isaac.
just looking at ease of swap...i'd look into doing the hasport si-vtec wiring harness, then do an obd conversion. im not sure if the teg wiring harness will work
a friend of mine rolled his 94 gsr. we bought one that had been stripped (theft recovery) and we had to use the wiring harness from the car that had been rolled. it was a bitch and a half to get it all pulled out then installed back in. it took a whole damn weekend just for that. got the car runnin great though
you can probably use the b17 harness, you will just have to still run the four wires which include the vtec, vtec oil pressure, knock sensor, and extra o2 sensor if youre using it. or you can use the si harness, and still do the same thing.
choice is yours
choice is yours
choice is yours
choice is yours
streetracerof06
Sep 2, 2005 07:16 AM
