ITR header on a JDM b16a
This is the header I want to get for my Rex too. Its supposed to fit, but then theres the thing about the two o2 sensors. Will have to make a spot for them I think..
this regarding the 4-1 JDM 98 specs ITR headers....(4-2-1 will work without problems)
it does fit...the front crossmember will need to be notched/cut out slightly otherwise it won't fit....the issue thats usually a problem is the road clearance if the car is low and the mount kit positions the engine even lower scraping will occur...the other isuues are 2.5" cat inlet...will need a test pipe or a aftermarket cat......2nd o2 sensor for non-obd cars will need to be welded in ....
Yes, it will fit. But you will need to:
1. Notch the front crossmember about 1/2 inch.
2. Either: A) tap that O2 sensor so that both O2 wires run off it or B) install a 2nd O2 sensor
3. Buy a 2.5 inch cat OR a transition pipe (2.5 inch collector to 2.25 tip).
HTH.
Loc
HTH.
Loc
SiR Inspired ED7
Nov 20, 2005 09:04 AM
exactvox
Jun 30, 2003 11:48 PM
91sifreak
Feb 13, 2002 09:17 PM
