Brake Rotor Replacements?
Old Jan 27, 2003 | 05:39 PM
RDLIN-IT's Avatar
Default Brake Rotor Replacements?
Its time for the brakes to be done on the R and while I would like to do the brembo brake set up, right now its kind of steep. What do any of you recommend other than stock? I am getting tired of cleaning the rust of the inside of my rims and the rust around the middle of the rotor looks like sh$.
Old Jan 27, 2003 | 05:58 PM
Aussie_ITR-0239's Avatar
New User
Default Re: Brake Rotor Replacements? (RDLIN-IT)
Apart from the 'rust' issue.... is there any other reason you don't want to fit OEM ones again?! Cause if it's only the rust, then simply buy yourself a can of 'brake caliper' paint (anything that can handle heat) in your choice of colour (I chose 'flat black'), remove the wheels, spray the offending area of disc & the caliper.... then you're good for about 6 or so months!!
NOTE: Don't be too concerned about any overlap onto the discs; as that'll soon rub/burn off, once you apply the brakes!
I too are in the market for some new front discs and are looking @ either the OEM ones again (as they've served me well for 126,000 kms + 10 track days), Spoon, EBC, DBA (Australian company) or Brembo. Don't be fooled, the Brembo discs are not that steep in price; as it is the quality/build of calipers, that makes their brake kits expensive.
When it comes down to it.... most discs are designed/built very similar and it's the brake pads, lines, caliper & fluid - that really determines your braking capability. Also don't buy x-drilled, as the cheaper (ie non Brembo, Ferrari or Porsche) discs are prone to heat-cracking near the holes = nasty!
Good luck mate....
[Modified by Aussie_ITR-0239, 1:01 PM 1/28/2003]
JDM CTR '00's Avatar
keep them stock
Old Jan 27, 2003 | 06:15 PM
Asahi's Avatar
stocks barely dust compared to others. Heard good things about Axxiss Ultimates and Andie at Cobalt is giving a discount to ITRCA/Expo participants.
We might have a new sponsor soon that is a OEM Brembo rotor supplier that can get us some deals.
Trey
Old Jan 27, 2003 | 07:26 PM
RDLIN-IT's Avatar
Default Re: Brake Rotor Replacements? (Aussie_ITR-0239)
Thanks for the help. I'll probably paint them this week and see how that goes.
Old Jan 28, 2003 | 06:57 PM
New User
Here's a couple of pictures for you to examine -
honvic
Suspension & Brakes
14
Mar 12, 2012 01:46 PM
mouab18c1
Suspension & Brakes
Apr 10, 2009 06:53 AM
Civic_07
Suspension & Brakes
May 5, 2008 09:31 PM
Han Solo
Jul 18, 2005 07:30 PM
isaldjgxi
Welding / Fabrication
Mar 27, 2005 12:34 AM
