Running rich.
Old Jan 27, 2003 | 04:32 PM
Tegra's Avatar
Default Running rich.
(95 LS) Im running very rich (aprox 20-21mpg) I usually get 25-28. I replaced the injectors, and FPR, new plugs, wires, cap and rotor. I've done all I can think of. I also have noticed a performance loss, and when i took off my intake and opened the butterfly on the throttlebody, I could see/smell a gas vapor cloud come out. Compression is fine, so is leakdown. Any ideas?
Old Jan 27, 2003 | 04:38 PM
Tegra's Avatar
Default Re: Running rich. (Tegra)
Somebody?
Old Jan 27, 2003 | 05:01 PM
97gSrkId88's Avatar
why didnt you change ur o2 sensor and pcv valve, that can make it run rich,
Old Jan 27, 2003 | 05:13 PM
Tegra's Avatar
Default Re: Running rich. (97gSrkId88)
Sorry, I changed the pcv valve(forgot to mention), and I didn't bother with the o2 because if thats bad doesnt it throw a code??
[Modified by Tegra, 8:16 PM 1/27/2003]
Old Jan 27, 2003 | 05:21 PM
CALM_AS_A_BOMB
Guest
Posts: n/a
QUICK catch him!! (hrhr)
make sure you have all the vacum hoses on the right way... FPR diaphram may be open
Old Jan 27, 2003 | 05:27 PM
Tegra's Avatar
Default Re: Running rich. (MUTANT X)
I checked all the vaccume hoses and I replaced the FPR with a new one, chances of them both being bad are next to nothing.
Old Jan 27, 2003 | 05:47 PM
Tegra's Avatar
Will a bad o2 sensor always throw a code?
livedew12
Jan 10, 2012 08:58 PM
Shonn
Oct 16, 2006 04:29 AM
JinteDgraM
Aug 14, 2005 08:12 AM
91_civicsi
Jun 21, 2004 12:13 PM
