Installing JDM 4-1
Old Jan 27, 2003 | 03:08 PM
95 Gizzer
Guest
Posts: n/a
Default Installing JDM 4-1
First of all, if I get the JDM 4-1 headers, gasket and 2.5" flange, will everything fit?
I know I have to have the flange welded on, but if I have a muffler shop weld it on, would I have them do it before I install the headers or what?
And is installing the headers as easy as team-integra.net makes it seem?
TIA
Old Jan 27, 2003 | 03:17 PM
emr88's Avatar
Default Re: Installing JDM 4-1 (95VTECGSR)
Installing the header is pretty easy, just be sure to use some penetrating oil like PB Blaster or Liquid Wrench on the bolts. I broke a header stud once, not fun. Not fun at all.
[Modified by emr88, 12:17 AM 1/28/2003]
Old Jan 27, 2003 | 04:02 PM
Adachi's Avatar
Yeah it's easy.. if the muffler shop is close, just put the header on before you go.. it will be a lot easier/faster for them to finish.
Old Jan 27, 2003 | 05:07 PM
stick's Avatar
ur gonna need a cat to fit the 2.5 inch collector (in) then to bolt up to ur exhaust(out). i hope u have both gaskets (donut gasket and cat/exh gasket).
might as well get a new exh mani gasket too.
it will be a tight fit. i went thru the bottom to put it it. remove the plastic shield under the radiator and AC bracket under the radiator too.
i would recommend a skid plate for that header to protect it from damages too.
Old Jan 27, 2003 | 06:22 PM
95 Gizzer
Guest
Posts: n/a
Default Re: Installing JDM 4-1 (Adachi)
So the header just wouldnt be put on all the way in the bottom?
Old Jan 27, 2003 | 06:33 PM
stick's Avatar
yes, u will be running open header and u will be very loud
Old Jan 27, 2003 | 06:34 PM
Adachi's Avatar
Yeah, just leave it running from the header.. you can't bolt it up anyways because it needs that flange, but your stock cat will still line up. It'll be loud though.. that's why I was saying I hope your muffler shop is close. Good Luck.
Old Jan 27, 2003 | 07:06 PM
Kelvin96GSR's Avatar
25 Year Member
you need a new cat. the JDM 4-1 is a different length than a stock GSR's. Who are you buying from?
Old Jan 27, 2003 | 07:14 PM
95 Gizzer
Guest
Posts: n/a
Default Re: Installing JDM 4-1 (Kelvin96GSR)
I'm getting it from inlinefour.com along with the gasket and flange. They said that it will fit if I get the gasket and flange
Old Jan 27, 2003 | 07:21 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
This is a quote I got from Dave at SMSP: But if you have a '95 GSR, then you'll need an OBD1 cat, which should be about the same price.
JDM donut is $15
3 bolt gasket is $4
hardware $5
2-1/2" 94066 OBDII kit is $185 and includes all the above.
David Stadulis
SMS Products
4755 Ewell Rd.
Fredericksburg, VA 22408
540-287-6384
smsproducts@earthlink.net
Old Jan 27, 2003 | 07:52 PM
nfn15037's Avatar
Most muffler shops should have the flange. Its just a flange with 4 3/4" bolt spacing for 2.5 inch pipe.
Old Jan 27, 2003 | 08:03 PM
Adachi's Avatar
Default Re: Installing JDM 4-1 (nfn15037)
nfn15037 is right, just take it to a muffler shop.. you don't have to worry about it too much.
Old Jan 27, 2003 | 08:13 PM
mugenracer's Avatar
Slightly O/T will the stock factory manifold gasket work with a DC JDM 4-1 (the gasket is brand new the header is not)?
Old Jan 27, 2003 | 08:18 PM
95 Gizzer
Guest
Posts: n/a
Default Re: Installing JDM 4-1 (mugenracer)
Am I gonna need anything special when I install the header?
Lube or anything?
Edit: Does anyone have a pic of what open header looks like?
[Modified by 95VTECGSR, 9:19 PM 1/27/2003]
Old Jan 27, 2003 | 09:16 PM
enginetiks's Avatar
I just happened to have a pic of the header on my car..This is what the finished product looks like.
Old Jan 27, 2003 | 09:40 PM
roydogg's Avatar
Default Re: Installing JDM 4-1 (mschvs)
That kinda doesn't look like the jdm 4-1 header. You will have to get a carsound cat that already has the welds or you can go to the muffler shop cuzz it will NOT fit with your stock cat.
Old Feb 1, 2003 | 08:05 PM
95 Gizzer
Guest
Posts: n/a
Default Re: Installing JDM 4-1 (roydogg)
Well I just installed the header, but its open header right now since the muffler shops are closed.
I took it for a test drive, and holy crap, that thing is damn loud. It is so distinct at 4400 RPM, and I couldnt even hear the secondaries at 5600.
I had my friend drop me off and then smash with me outside the car, and its even louder when youre on the outside. Neighbors got out of their houses when he drove by.
Anyways, the stock cat doesnt look like it will fit once I have the 2.5" flange welded on. Does anyone have any experience with this?
Hopefully the muffler shop will be open tomorrow since it's pretty much undriveable right now...
Old Feb 2, 2003 | 07:47 AM
nfn15037's Avatar
xunkn0vvnx
Sep 11, 2005 06:52 PM
RGoose18
Nov 12, 2003 11:57 AM
tampaSi
Mar 22, 2002 03:29 PM
Isaac
Dec 1, 2001 10:15 AM
