HELP: is there any difference between 1998 JDM itr 5 lug and usdm?
is there any difference between jdm and usdm 5 lug suspension in 1998?? Any advice is appreciated. Thx
I think their is a difference in one of the arms, but I am not sure. Someone should know for sure.
Guest
Posts: n/a
Yes the usdm 32mm and the jdm is 36mm witch means if you have a anything other that a b18c your gonna have to change the axles to a 36mm axle. I think? But I do know that the axles are different
are the axles you mean different in length? Why B18C? are the si axles different from type r axles? are itr usdm axles different length from jdm itr axles?
The above post was correct in that the outer axle and hub are 36 mm instead of the USDM stock 32mm.
Either ones should fit into the transmission, just that the hubs/bearings will need to be the JDM 36mm version to fit the bigger outer axle stubs. Ed
Given the fact that the seller is including JDM driveshafts with the JDM 5 lug suspension, will there be any troubles installing this onto an ek? I noticed that the compensator arms in the rear are longer than the usdm ones
