Rear Vented Brakes on ITR ? Advantages ? Please Respond !
Old Jan 27, 2003 | 08:58 AM
TsunamiZC's Avatar
Default Rear Vented Brakes on ITR ? Advantages ? Please Respond !
Would Rear Vented Brakes be Advantageuos on a ITR .....particularly on hard braking .....or braking around corners ....
for street use i wouldnt see much of a gain other than maybe a bit more stability in emergency braking procudures ..etc
but for track duty , would they be helpful ?
would it be possible to use front calipers , and rotors from a ITR ...and impliment them in the rear ?
Old Jan 27, 2003 | 09:01 AM
sgT's Avatar
sgT
Default Re: Rear Vented Brakes on ITR ? Advantages ? Please Respond ! (tsunami_zc)
not that much braking is done in the rear
Old Jan 27, 2003 | 09:04 AM
TsunamiZC's Avatar
Default Re: Rear Vented Brakes on ITR ? Advantages ? Please Respond ! (sgT)
so i guess it would be kinda useless then ......
Old Jan 27, 2003 | 09:08 AM
Back in Black's Avatar
Rather OG
Yep. The fronts take the majority of the abuse.
Old Jan 27, 2003 | 09:10 AM
SurferX's Avatar
Default Re: Rear Vented Brakes on ITR ? Advantages ? Please Respond ! (Jason Franza)
Why do the rear pads then wear as quickly or sometimes quicker than the fronts then?
Old Jan 27, 2003 | 09:12 AM
sgT's Avatar
sgT
Default Re: Rear Vented Brakes on ITR ? Advantages ? Please Respond ! (SurferX)
i average 2 sets of fronts for 1 set of rears normally.
but every car is different.
.RJ's Avatar
.RJ
Likely using a softer compound i would guess. I toasted a set of rear Carbotech Kelate Metallic (autocross compound) after one weekend when i forgot to swap them out to OE's. They have a very low temp threshold.... I was getting 3 weekends on a set of fronts.
Old Jan 27, 2003 | 09:20 AM
TsunamiZC's Avatar
Default Re: Rear Vented Brakes on ITR ? Advantages ? Please Respond ! (Indecisive.RJ)
would using front rotors on the rear even work ? would it bolt up ?
Old Jan 27, 2003 | 09:44 AM
sgT's Avatar
sgT
well, you would have to space them correctly and fabricate adapters to bolt up the
front calipers as well.
Old Jan 27, 2003 | 10:13 AM
TsunamiZC's Avatar
its a bad idea i guess ...the brake master cylinder prolly wouldnt handle it either ...oh welll ...
Old Jan 27, 2003 | 10:16 AM
SlapSmak's Avatar
and the proportioning valve is not setup to accomodate that size rears.
Dom_GsR
Aug 10, 2004 07:34 PM
96 SOHC VTEC
Nov 30, 2002 07:49 PM
BrandonClaps
Sep 5, 2002 03:57 PM
integra*RS*
May 20, 2002 10:03 PM
