Q: Which gasket to use for _Stock cat_ + _2.38-3.5"_ cat-back exhaust.
Question: Which gasket should I use for a stock catalytic converter mated to a 2.38" b-pipe (Mugen twinloop)??
Obviously running stock "triagular" gasket will fit perfectly for the cat, but it'll block some of the holes of b-pipe (since it is larger in diameter). On the other hand, if I use gasket for 2.5", then there is only a little material to seal up the catalytic mating surface... which might lead to exhaust leakage. (Does any of this make sense??!?
Anyone running mugen twinloop mated to stock cat?
Thanks.
)Anyone running mugen twinloop mated to stock cat?
Thanks.
stock doesn't not have a gasket.
bolt it up and r0ll with.
Thanks for the info, Will! I didn't have helm's manual last night and I couldn't find the stock gasket!
Sweet, so I don't need to buy any gaskets.
I'm a we-todd.
invisible
Jan 9, 2009 09:22 AM
Ill
Sep 27, 2003 08:39 AM
