OEM ITR clutch
it means they arent the same. you need to supply more information so we can answer your question with more detailed information, such as if it is a Del sol VTEC and has a B16 or not. If it is a B16, then the clutch may work, but will only have 6 bolts instead of 9 which the ITR has. If its not a B16 then dont bother and it will not work.
OK, heres the full story. I bought 2 Action 2MD clutches. They sent me 2 identical ones and said that they'll fit both cars - Del Sol VTEC B16A2 and ITR B18C6.
Installation went smoothly and its now in the Del Sol running happily. On the ITR, installed no problem but gears would not engage. What could be the problem? Could taking off 20 thous off the front of the stock flywheel correct the problem?
Drag-On
Apr 21, 2004 03:00 AM
