What else do I need for 80shot direct port?
I'm planning on getting NOS brand 80 shot nitrous direct port for my b20/b17 with completely stock internals. I have p3k pistons which yields me about 9:1 compression. I'm running JDM PR3 w/ Mugen program(4500vtec/no rev limit). This is the stuff I have so far what else do I need? or do you recommend me getting?
B&M FPR & Gauge
NOS brand nitrous pressure gauge
bottle warmer
purge kit
NGK 7 heat rating plugs
MSD 7AL-2
MSD Blaster 2
Accel plug wires
The thing that worries me is the stock injectors and the stock fuel pump. I recently replaced the fuel filter. I know as a fact that the injectors have never been cleaned before and the pump is original.
Also what number jets are for 80shot?
Jay Kim
B&M FPR & Gauge
bottle warmer
purge kit
MSD 7AL-2
MSD Blaster 2
Accel plug wires
Jay Kim
I would definately get a larger fuel pump, but i also think u need to worry about the ecu program u have as most programs advance timing which wouldn't be good for the nitrous. Paul
technically u dont need a pump but i wouldnt run w/ out a 255lph. an ignition will do u wonders simply becuase u will be able to retrd timing only when spraying.
go w/ a msd digi 6 ...by far the best ignition.
colder plugs/./ngkbkr7e, pump and ignition will go a LONG WAY!
pm me, i have a lotta spare n20 parts for dp i need to get rid off asap..cheap.
or call 281 827 2381..they are all new.
roby
roby
NAcivicEK
Apr 29, 2003 04:09 PM
SpeednSol
15
Feb 22, 2003 04:23 PM
