how to wrap your exhaust ?'s
Old Jan 26, 2003 | 06:24 PM
evoeone's Avatar
Default how to wrap your exhaust ?'s
i know you buy the roll and the hose clamps, is it s sticky roll kind of thing? or do you lay down the silicon spray underneath, or over.
how have you guys done it? and what about wrapping over the flex, do you think it would "flex" the wrap loose?
basically just post how you guys have done it , results, do'd, dont's, pointers etc. links for teh cheaoest wrap.
i'm making a dp, aluminized steel, i was thinking of painting it with maybe silicone spray or high temp rustoleum to protect , then wrap,
TIA
Old Jan 26, 2003 | 07:08 PM
Full-Race Javier's Avatar
Default Re: how to wrap your exhaust ?'s (evoeone)
FWIW, i wrapped my stainless DP and it cracked with in a couple of months. the easiest way to wrap it is to have a friend help. first get the wrap wet, then wrap the pipe. when its wet, its easier to install, its also less itchy. when the pipe heats up and drys off, the wrap tightens up a little.
Old Jan 26, 2003 | 07:22 PM
evoeone's Avatar
Default Re: how to wrap your exhaust ?'s (javierb14)
wet with what? water, adhesive silicone spray
Old Jan 26, 2003 | 07:37 PM
water
pagong's Avatar
i didnt know about wetting the wrap...no wonder i was hella itchy after the install.
Old Jan 26, 2003 | 08:08 PM
evoeone's Avatar
Default Re: how to wrap your exhaust ?'s (pagong)
ok cool, thanks, so i'll just wet, wrap and hose clamp. TIA
curtie94
Honda Motorcycles
May 9, 2011 06:31 AM
dbayton
Welding / Fabrication
11
Aug 23, 2010 05:04 AM
NZstan
Apr 16, 2010 09:15 PM
head458
Jul 24, 2009 04:38 AM
kraig
Jun 6, 2004 12:32 PM
