anyone know an easy way to replace the front main seal?
Old Jan 26, 2003 | 06:10 PM
Boostless97Lude
Guest
Posts: n/a
Default anyone know an easy way to replace the front main seal?
ok, so i ******* replaced it once, and the leak got WORSE!!!! i am so pissed off, anyways, is there some kind of trick to putting in a new seal while the engine is still in the car??? i know people do that **** all the time, but what's the easy way to do it??
Old Jan 26, 2003 | 08:15 PM
Flamenco-T's Avatar
Default Re: anyone know an easy way to replace the front main seal? (Boosted97Lude)
you mean the oil pump seal ?
Old Jan 26, 2003 | 09:06 PM
dustin's Avatar
For the flywheel side you just take the oil pan off and unbolt the cover and it is pressed into the cover. Pound it out of the cover and press a new one in.... reinstall cover....
You have to remove the tranny/flywheel first..
Make sure you press the new one in perfectly evenly and do not deform the seal edge..
Old Jan 26, 2003 | 10:28 PM
InfamousRS's Avatar
Default Re: anyone know an easy way to replace the front main seal? (dustin)
I also had to lube mine up real good before it would go in straight ...
Old Jan 26, 2003 | 10:43 PM
Flamenco-T's Avatar
Default Re: anyone know an easy way to replace the front main seal? (InfamousRS)
use a large flat object then hammer it to get an even presure in the opening..
tap it slightly around the edges...
Old Jan 27, 2003 | 02:54 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: anyone know an easy way to replace the front main seal? (Flamenco-T)
main seal on the oil pump side is what i need to replace..... yes, i know i need to take off all that ****, like i said, i've already done it once, i was just wondwring if anyone knew a trick for instaling it, aparently thay have to go in PERFECT or they don't seal up right, b/c now my leak is worse
Old Jan 27, 2003 | 03:38 AM
TheWickedOne's Avatar
The trick to install the font main and the rear main seal is to use the old seal to tap it in, meaning take the old seal and place it on top of the new one, by doing this it will prevent damage to the new seal when it is being tapped in by a mallet or a hammer.
Just my 2 cents..
Old Jan 27, 2003 | 06:45 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: anyone know an easy way to replace the front main seal? (TheWickedOne)
i wish i could ust tap it in with a mallet or hammer, but the thing is, i am replacing it with everything still on the engine, while it's inside the car
Old Jan 27, 2003 | 08:01 AM
sgT's Avatar
sgT
personally, i rather pull the pump off and do it off the car.
or you could buy a seal driver
Old Jan 27, 2003 | 09:07 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: anyone know an easy way to replace the front main seal? (sgT)
you have any idea how much work that involes on an H22???
Old Jan 27, 2003 | 09:14 AM
sgT's Avatar
sgT
yep. i sure do.
and i rather pull the pump and do it ONCE.
Old Jan 27, 2003 | 09:23 AM
Boostless97Lude
Guest
Posts: n/a
well, i already did it once actually, i am just gonna see if i can find a big enough deep socket to place over it todrive it in nice and even
Old Jan 27, 2003 | 10:59 AM
sgT's Avatar
sgT
like i said, you could always buy the driver
Old Jan 27, 2003 | 07:10 PM
Flamenco-T's Avatar
true, they're pretty cheap, less than 20 bucks for a set, or just take it to a dealer and sneak in the back to the mechanics and have them do it for you for 5 bucks
Old Feb 1, 2004 | 12:02 PM
Erik_Pb_Foot's Avatar
New User
can someone provide a link to a step-by-step how-to do do this on a d16y7? what exactly is involved and are their any tricks or tips to help the install goe easier?
pictures would be great.
thanks
erik
Old Feb 1, 2004 | 12:15 PM
speedworks's Avatar
Default Re: anyone know an easy way to replace the front main seal? (Erik_Pb_Foot)
a great man told me once (you must be smarter than what you are working on)
Old Feb 1, 2004 | 12:21 PM
New User
Default Re: anyone know an easy way to replace the front main seal? (speedworks)
ummmmm, ok...
so no pictures 'eh?
Old Feb 1, 2004 | 12:23 PM
turbo96wr's Avatar
Default Re: anyone know an easy way to replace the front main seal? (Boostless97Lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostless97Lude &raquo;</TD></TR><TR><TD CLASS="quote">ok, so i ******* replaced it once, and the leak got WORSE!!!! i am so pissed off, anyways, is there some kind of trick to putting in a new seal while the engine is still in the car??? i know people do that **** all the time, but what's the easy way to do it??</TD></TR></TABLE>
you just have to remove everything from the oil pump side and install the new seal, what you have to pay attention to is when you place the seal over the crank and in the socket that you did'nt pull the seal spring out of place because that is what will give you the leak,. place it in carefully making sure when you are pressing it in that the inner edge of the seal did'nt pinch and push it with your fingers as far as you can, then you could use a flat tip brass punch and tap it in gently will work.
Old Feb 1, 2004 | 12:25 PM
turbo96wr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik_Pb_Foot &raquo;</TD></TR><TR><TD CLASS="quote">can someone provide a link to a step-by-step how-to do do this on a d16y7? what exactly is involved and are their any tricks or tips to help the install goe easier?
thanks
erik</TD></TR></TABLE>
same exact step on your motor
Old Feb 1, 2004 | 12:30 PM
New User
Default Re: anyone know an easy way to replace the front main seal? (turbo96wr)
what about replacing the seal without taking the oil pump from the car? can't i just tap the seal in a little at 5 o'clock and then jimmy it out little by little?
Old Feb 2, 2004 | 01:51 AM
GOLDBERG's Avatar
how do yah change rear main seal when the motors in car..?any tricks?
Old Feb 2, 2004 | 07:18 AM
New User
Default Re: anyone know an easy way to replace the front main seal? (GOLDBERG)
gotta pull the tranny off, then remove the flywheel.... you can do it in the car....
Old Feb 2, 2004 | 08:03 AM
Bailhatch's Avatar
the reason it may have leaked the first time is that the seal of the inner lip was being compromised by the slight wear path of the old seal. Generaly you want to install oil seals at a different depth so they make their own sealing surface.
Just push it in an extra 2mm and it will have a better chance of sealing reliably.
ya also make sure it isn't folded up inside like someone already said.
for doing front seals in the car you can use a curved bar of some sort to pry against the body of the car. it can give you much better control than using a hammer and drift, if there is even room for that.
Old Feb 2, 2004 | 08:13 AM
earl's Avatar
Default Re: anyone know an easy way to replace the front main seal? (Bailhatch)
Also check the area where the seal fits into. If it is dinged or out of round, your leak could be there. You should be able to look at where the seal is touching the crank snout and see why it failed. When all else fails, replace the pump and it will come with a new seal. That pump costs around $150 and lots of extra work because of the half shafts (as you well know )
dads95ss
Jul 14, 2012 07:45 PM
raj49
Jul 7, 2011 09:01 AM
lude98SH
Oct 6, 2008 03:31 PM
curreds
Jan 9, 2004 09:02 AM
BlueSi2k
May 31, 2003 01:57 PM
