JDM type R 4-1 headers, dremeling out welds?
Old Jan 26, 2003 | 11:14 AM
ChapR
Guest
Posts: n/a
Default JDM type R 4-1 headers, dremeling out welds?
When I smooth out the welds inside my jdm type r 4-1 headers, do I need to weld the outer tube for extra strength?
Old Jan 26, 2003 | 11:34 AM
hungsteR's Avatar
Default Re: JDM type R 4-1 headers, dremeling out welds? (ChapR)
You don't have to as long as you don't dremel off too much of the weld. You could always weld the outer for added security.
Old Jan 26, 2003 | 11:42 AM
Misfit's Avatar
Default Re: JDM type R 4-1 headers, dremeling out welds? (hungsteR)
how much gain are you getting with all this trouble anyway? shrugs
Old Jan 26, 2003 | 12:11 PM
Agent#ONE's Avatar
Default Re: JDM type R 4-1 headers, dremeling out welds? (MISFIT)
its a good idea to add welding on the outer areas.
then go to town with your dremmel.
a ported itr header ive seen gain 6hp up top.
Old Jan 26, 2003 | 05:46 PM
Padawan's Avatar
Darth ModerVader
I have no personal experience with welding the primaries (perhaps Dave at SMSP could offer his knowledge here), but all the information I've come across indicates that the flange should be bolted to a jig before being welded to prevent warping.
Old Jan 26, 2003 | 07:44 PM
Tommy_Gunns's Avatar
Default Re: JDM type R 4-1 headers, dremeling out welds? (Padawan)
Would it warp if you welded the outside before dremeling away the old weld?
Old Jan 26, 2003 | 07:53 PM
Padawan's Avatar
Darth ModerVader
Default Re: JDM type R 4-1 headers, dremeling out welds? (Tommy_Gunns)
Yes, it is the flange itself that would be warping from the heat of the welding - having it bolted to a jig would keep it true during the welding and as it cooled. Either way, you would probably want to complete the outer welds before griding the factory inner ones.
EDIT: Again, I'm not saying that the flange would definately warp, I'm simply stating what all the information I've seen has indicated.
[Modified by Padawan, 12:11 AM 1/27/2003]
Old Jan 26, 2003 | 08:08 PM
R3dL1n3's Avatar
after this u could also pump out or cut out the inner pipe of the collector.
Old Jan 27, 2003 | 06:01 AM
XR4racer's Avatar
Just smooth it out..
Old Jan 27, 2003 | 06:53 AM
SMSP's Avatar
If you have access to compressed air, go to Wal Mart and buy you a cheap air grinder that accepts 1/4" shanks. Go to a welding shop and buy a carbide burr. Do it with these tools and you'll save yourself a couple of hours versus the dremel. Ask D
USE SAFETY GLASSES!
Then just "clean" up the welds. Use common sense, don't go crazy just get the bumps off that look like they would be in the flow path. If you don't start cutting into the tubing you shouldn't have to do any welding on the outside. I did this to Robert's header 2-3 years ago and I guess it hasn't cracked yet and he's even been in an accident or two . Just remember the weakest part of a welded joint is the thinnest piece (assuming all the material is the same spec).
Old Jan 27, 2003 | 10:33 AM
ChapR
Guest
Posts: n/a
Default Re: JDM type R 4-1 headers, dremeling out welds? (SMSP)
Thanks SMSP! I wanted to sand mine out like this.
Old Jan 27, 2003 | 12:40 PM
GRM Scott's Avatar
25 Year Member
heh, that's my wheel!
more pix up on our site of D's kuzt0m dremel job.
Old Jan 27, 2003 | 12:47 PM
-Whitey-'s Avatar
Default Re: JDM type R 4-1 headers, dremeling out welds? (Aleph)
just touch it up dont go all out and remove everything..if you want a header with no inner welds buy a dc sports jdm 4-1 header it comes pre what your trying to do to the honda header
Old Jan 27, 2003 | 12:52 PM
Doctor CorteZ's Avatar
I did it and I think its a very good mod , besides its cheap.
Old Jan 27, 2003 | 01:20 PM
Hooch'n's Avatar
Default Re: JDM type R 4-1 headers, dremeling out welds? (Doctor CorteZ)
Old Jan 27, 2003 | 02:38 PM
Smitdog's Avatar
Default Re: JDM type R 4-1 headers, dremeling out welds? (Hooch at 8400-RPM)
Did not bother with mine...........
Old Jan 27, 2003 | 05:23 PM
Tweakmeister's Avatar
Default Re: JDM type R 4-1 headers, dremeling out welds? (Smitdog)
when I get one I'll do it...
Old Jan 27, 2003 | 09:31 PM
2fknlo's Avatar
For the jig would it be alright to bolt the header to a peice of 2x4 wood and then start welding it?
thanks
projectTeG
Oct 17, 2008 10:41 AM
Obese
Mid-Atlantic (Sales)
Mar 29, 2007 05:45 AM
Audipwr1
Jul 28, 2003 04:30 AM
juicy.koreans.suck
Jan 24, 2002 01:19 AM
