Did i order the wrong fittings for my paxton FPR or what??? this sucks...
Old Jan 25, 2003 | 10:39 PM
accordfreak's Avatar
Default Did i order the wrong fittings for my paxton FPR or what??? this sucks...
my intentions were to reduce the size from -10an to -6... and the fitting hits the bottom when it's screwed in making it like a plug... plus the fitting doesn't even finish screwing in before it hits the bottom.... please help!
edit: copy and paste this link for the instructions that came with the FPR http://www.imagestation.com/picture/...b.jpg.orig.jpg
[Modified by accordfreak, 7:41 AM 1/26/2003]
Old Jan 26, 2003 | 12:30 AM
ninesecrx's Avatar
Default Re: Did i order the wrong fittings for my paxton FPR or what??? this sucks... (accordfreak)
you need to add a big rubber O-ring at the end of the fitting so it doesnt bottom out. You also need this to help it seal as well.
Old Jan 26, 2003 | 07:56 AM
boostaholic's Avatar
Default Re: Did i order the wrong fittings for my paxton FPR or what??? this sucks... (ninesecrx)
You need to cut off the end of those AN fittings. Cut it just before where the threads start.
Old Jan 26, 2003 | 09:16 AM
tony1's Avatar
Default Re: Did i order the wrong fittings for my paxton FPR or what??? this sucks... (boostaholic)
Exactly, you need to cut a little off the big end. Normally AN fittings seal on the 37 deg. angle at the end, but in this situation it seals with the oring. Cut it and install an oring. Everything will work fine.
Old Jan 26, 2003 | 11:32 AM
civbeater90's Avatar
Default Re: Did i order the wrong fittings for my paxton FPR or what??? this sucks... (tony1)
o rings
Old Jan 26, 2003 | 02:35 PM
Default Re: Did i order the wrong fittings for my paxton FPR or what??? this sucks... (civbeater90)
man thanks a LOT! i thought i had to buy new fittings. h-t is great!
Old Jan 30, 2003 | 09:47 PM
okay i found the o-rings but which kind should i get?? what is the difference between the two??? Buna N OR Viton
http://www.amstreetrod.com/html/seals.html#ob
Old Jan 30, 2003 | 09:51 PM
Flamenco-T's Avatar
either one of them should work. I used autozone ones
stan
Type-ARR
Jun 29, 2007 11:13 AM
preveink
Welding / Fabrication
Mar 14, 2006 07:34 PM
esoterEK..
May 4, 2004 06:32 PM
johnzm
Nov 19, 2003 08:03 AM
Mikey3000
May 2, 2002 11:04 AM
