... loose shifter box...
Old Jan 25, 2003 | 09:19 PM
1.8T_EG's Avatar
Default ... loose shifter box...
... my winter beater's (87 civic) shifter box is really loose... for example if you are in any gear, still moves around freely to the point that it can still touch the front seats... anyone have any suggestions?... i was told that it is probably a linkage problem and that a short shifter kit would help... any thoughts?... if so, anyone know of a short shifter kit for an 87 civic?... i have seen some on ebay for 88 and up, but none for an 87... lemme know... thanks...
Old Jan 25, 2003 | 10:33 PM
Trinity's Avatar
Default Re: ... loose shifter box... (1.8T_EG)
you don't need a short throw shifter just tighten up your shift linkage. trust me that should fix the problem
Old Jan 26, 2003 | 12:18 AM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: ... loose shifter box... (Trinity)
what she said. and check your bushings down there as well.
Old Jan 26, 2003 | 04:47 AM
EGchino's Avatar
Default Re: ... loose shifter box... (Ham'ed Hatch)
Bushing........$9~$10 on Ebay. Will change everything.
Old Jan 26, 2003 | 07:36 PM
1.8T_EG's Avatar
Default Re: ... loose shifter box... (Lost Projects Performance)
...couldn't find any on ebay... maybe i'm searching the wrong keywords? ...anyways... got a link? thanks.
Old Jan 26, 2003 | 07:40 PM
Camshaft's Avatar
check the shifter bushing or the universal joint at the transmission.
The swivel joint at the end of the shifter rod always wears out..
cam
Old Jan 26, 2003 | 07:56 PM
USDM 4G VTEC's Avatar
either that or ur pin its getting loose, in case u dont have the clip holding it.... but i been there and a bad pin will make shifter wably and bad bushings also... it just either one
JDMswagSerf
Dec 20, 2013 10:31 PM
cobracmndr
Jul 28, 2008 05:53 PM
Simple
Aug 21, 2005 11:28 PM
treplatano
16
Aug 12, 2005 10:50 PM
gameknb
Jun 11, 2005 07:32 AM
