Fuel Injector/Rail install help ASAP(its cold as a muthaf0cka out there!)
Old Jan 25, 2003 | 12:01 PM
RTW DC2R's Avatar
Default Fuel Injector/Rail install help ASAP(its cold as a muthaf0cka out there!)
Do I need to lube or hondabond any of the yellow circled areas? I checked out Cspeed for their How To on fuel rain installs, and they only lube the o-rings on the top of the injectors, not the bottom seals, and dont mention anything about lubing/hondabonding the bolts/fittings on the end of the fuel rail. Try to reply asap because Im losing light and its brick outside. Thanks
Ryan, who is hawwwdcore y0!
Old Jan 25, 2003 | 12:15 PM
markpaco's Avatar
Default Re: Fuel Injector/Rail install help ASAP(its cold as a muthaf0cka out there!) (RTW DC2)
a little oil is fine. Just so you don't destroy them going in.
Old Jan 25, 2003 | 12:27 PM
RTW DC2R's Avatar
Default Re: Fuel Injector/Rail install help ASAP(its cold as a muthaf0cka out there!) (markpaco)
another question...in the below picture, on the left end of the fuel rail where the fuel line connects, there is a piece called a "pulsation damper", and there is a strange washer(called a muffler gasket) and a 12mm washer...I dont know what order these go in when installing them. Helms doesnt say and I cant find it on any engine pics or acuraautomotiveparts.org
I show you guys a pic in a sec....
Is this the correct order these need to be installed in???
This is what it would look like all hooked up...it just seems to me that the washers/gasket are cutting off the fuel supply to the rail....:shrugs:
[Modified by RTW DC2, 4:42 PM 1/25/2003]
[Modified by RTW DC2, 4:47 PM 1/25/2003]
Old Jan 25, 2003 | 12:42 PM
RTW DC2R's Avatar
added picture to last post
Old Jan 25, 2003 | 01:02 PM
Splat's Avatar
Collector-o-Guns and Drinker
Send me that stack of twennies and I'll find out for you
Old Jan 25, 2003 | 01:09 PM
RTW DC2R's Avatar
Default Re: Fuel Injector/Rail install help ASAP(its cold as a muthaf0cka out there!) (Splat)
Old Jan 25, 2003 | 01:16 PM
Rob Dizzle's Avatar
you are correct withthe muffler/notched washer. it is that way so that fuel can flow into the rail.
Old Jan 25, 2003 | 01:26 PM
RTW DC2R's Avatar
Default Re: Fuel Injector/Rail install help ASAP(its cold as a muthaf0cka out there!) (Bob-DC2)
Thats what common sense told me but I just wanted to be sure.
Also, anybody know the torque spec of that end cap(pulsation dampener)? I dont see it in the Helms
[Modified by RTW DC2, 5:29 PM 1/25/2003]
Old Jan 25, 2003 | 04:34 PM
RaVAGE00's Avatar
New User
is that real money... man that us money looks fake...
Old Jan 25, 2003 | 06:51 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
hey rtw, sorry i got back to you so late, i had issues with christian's seats... in that last pic, you have it correct.
Old Jan 25, 2003 | 06:57 PM
EndlessGarageEG6's Avatar
Default Re: Fuel Injector/Rail install help ASAP(its cold as a muthaf0cka out there!) (RaVAGE00)
may look fake but it has its purpose.
to stop counterfits.
Old Jan 25, 2003 | 08:20 PM
TypeR 01 886's Avatar
Default Re: Fuel Injector/Rail install help ASAP(its cold as a muthaf0cka out there!) (CRintegreX)
Are you boosted? Why do you have the AEM fuel rail?
Old Jan 25, 2003 | 10:17 PM
CWESTINAP1's Avatar
Default Re: Fuel Injector/Rail install help ASAP(its cold as a muthaf0cka out there!) (TypeR 01 886)
i have rc 310 cc injectors just like those i think? if hez using 310's? they're new, sealed in box if anyone wants them. $260.
Old Jan 26, 2003 | 08:07 PM
CWESTINAP1's Avatar
Default Re: Fuel Injector/Rail install help ASAP(its cold as a muthaf0cka out there!) (CWESTINDC2)
i also have a question. i have the same intake manifold, and im confused where to connect the second hose for my oil catch can. i know where it would go on a stock type r intake manifold but not on a victor x. can someone help? thanks
lickety_britches
Apr 22, 2009 06:19 PM
johnwohl
Feb 10, 2008 11:07 AM
anothersickhatch
Nov 7, 2007 05:20 PM
jdmcivic1999
Dec 5, 2005 09:21 AM
thehondaguru
Oct 11, 2002 05:33 AM
