ACT...Which clutch for my setup
Old Jan 25, 2003 | 10:11 AM
BoostedH23a1's Avatar
Default ACT...Which clutch for my setup
i was thinking XTSS...
boosted h23 @7psi
untuned dyno at 250whp
s200 is in the mail.
more boost will be comming..
its a dailydriver and i dont want to have to rev to like 4k to slip it..
Old Jan 25, 2003 | 10:14 AM
Firedrake's Avatar
Default Re: ACT...Which clutch for my setup (BoostedH23a1)
I replied in the prelude forum, but you should be great with an HDSS
Brian
Old Jan 25, 2003 | 10:15 AM
boostaholic's Avatar
That clutch should do just fine.
Old Jan 25, 2003 | 10:19 AM
Default Re: ACT...Which clutch for my setup (boostaholic)
XTSS or HDSS which one... whats the petal difference between the 2
if nothing then i would just get XTSS
Old Jan 25, 2003 | 10:37 AM
Daniel's Avatar
act's webpage says the XTSS can hold a bit more torque than the HDSS. and the extreme pressure plate probably feels a little stiffer than the heavy duty PP.
edit -- looked at the act page again, and they say it'll hold a lot more torque than the HDSS w/ a 95% pressure increase compared to the HDSS' 41%.
[Modified by Daniel, 7:40 PM 1/25/2003]
Old Jan 25, 2003 | 10:42 AM
Default Re: ACT...Which clutch for my setup (Daniel)
so thats like pushing in on a brick wall?
Old Jan 25, 2003 | 10:43 AM
damnit i need to drive somes car that has one
Old Jan 25, 2003 | 11:04 AM
I've installed both the HD and XT pressure plate. The extreme grabs harder but the pedal is pretty stiff. I personally like a stiff clutch pedal and you'll get used to it, IMO.
Old Jan 25, 2003 | 11:38 AM
damnit is there a way to descibe how stiff.. i know u have a civic and my lude is harder than civics stock... i bet mine will be hella hard.
Old Jan 25, 2003 | 12:23 PM
Firedrake's Avatar
The HD feels like stock to me, the XT is about 50% more effort than the HD.....either one will be fine, the pedal pressure isn't a big deal as long as you are using a disc, if it were a puck then it'd be a huge PITA....
You'll like either one, but my opinion is get the HD and enjoy the driving more (especially if it's your daily driver and/or other peeps like a GF drive it)....besides, when you do a built motor to make the power that the XT can hold, you'll want to swap out your clutch again anyways......that's what I'm planning
Brian
Old Jan 25, 2003 | 12:29 PM
Default Re: ACT...Which clutch for my setup (Firedrake)
yea...sounds like HDSS time
Old Jan 25, 2003 | 02:12 PM
turbotypeR@SPEC's Avatar
25 Year Member
i had the xtss on my itr and the pedal did not feel any stiffer than stock,it just engaged quicker.by the way,it started slipping once i got over 300 lbs ft and about 2 years of abuse.i think it is a very good clutch and it is the one i would use in your case.
Old Jan 28, 2003 | 09:51 PM
ineedboostbad's Avatar
Default Re: ACT...Which clutch for my setup (turbotypeR)
Clutch Masters Stg 4
a1320addict
Nov 16, 2005 03:44 PM
SuicideSlide
11
Aug 29, 2004 01:25 PM
jolt-tsp
Honda S2000
Apr 27, 2004 03:18 PM
a z n t a k
Apr 8, 2002 09:53 PM
