91si brakes squeaking!!!!!!!!!!
Old May 18, 2001 | 08:20 AM
WuShu's Avatar
New User
Default 91si brakes squeaking!!!!!!!!!!
My front brakes are squeaking like hell everywhere i drive, anyone know what the culprit is? I had this same problem with my rear brakes and it was because i had worn out my brake pads. I know this is probably the case up front but what else could be causing this. also, my brake bads wear out wayyyy to fast, what could be going on? My guess is my rotors are warped. What do you guys think?
Old May 18, 2001 | 09:50 AM
REDBARON's Avatar
Default Re: 91si brakes squeaking!!!!!!!!!! (HondaCRX)
More than likely your brake pads are gone. Also Take the rotors off the car and have a brake shop re-surface them. Also do you have OEM or aftermarket brake pads?
Old May 18, 2001 | 11:32 AM
WuShu's Avatar
New User
Default Re: 91si brakes squeaking!!!!!!!!!! (89-T-Rex)
I have just regular oem pads, but which are the best aftermarket pads? Inexpensive too? I want to also get crossdrilled and slotted rotors who makes some nice cheap ones?
Old May 18, 2001 | 12:43 PM
REDBARON's Avatar
Well maybe it's due to the way you drive.
And there are a lot of brake pads, you have to do some
research on that.
turnsignalandy
Nov 12, 2006 03:35 AM
old_school_dohcvtec
Apr 30, 2005 07:47 AM
faSHOwidIT
Apr 18, 2005 02:06 AM
InTeGrA_bLazEd
Oct 14, 2003 12:47 AM
integra0260
Oct 21, 2001 08:09 AM
