Knocking/Rattling sounds when Braking HARD???
Old Jan 24, 2003 | 05:56 PM
jjj784's Avatar
Default Knocking/Rattling sounds when Braking HARD???
hey guys, I'm hearing knocking (clock-clock-clock) sounds when I brake hard. There are no sounds under normal braking, but only when I brake somewhat hard. I took off the wheel and checked the brakes, cv boot, and axles, and I found nothing wrong. no grease or brake fluid leaking, and no cracks in the boot either. btw, it's a 96 accord. what else should i look for? thanks.
i also checked the end axle nut, and that is tight. would it be loose brake pads?
Old Jan 24, 2003 | 07:07 PM
Crono139's Avatar
Default Re: Knocking/Rattling sounds when Braking HARD??? (jjj784)
Anything in your trunk that could be making that noise? My car makes noises when I brake hard, too. That's because I have my stock intake, and the little foghorn thingy I removed from when I installed my DC Sports intake recently, in my trunk. Too lazy to go put that stuff in my shed.
[Modified by Crono139, 4:08 AM 1/25/2003]
Old Jan 24, 2003 | 07:17 PM
philipkrotch's Avatar
rotors and brakes aer el' junko. mine are..does the same ****..only under hard braking from higher speeds.
Old Jan 24, 2003 | 07:24 PM
jjj784's Avatar
Default Re: Knocking/Rattling sounds when Braking HARD??? (philipkrotch)
naw, it's not my trunk. you can totally hear it in the front when you brake. perhaps it's the brakes? maybe it's time for an AEM big brake upgrade. hehe.
Old Jan 25, 2003 | 08:38 AM
YodiBrodi's Avatar
it's probably just your ABS kicking in. does your brake pedal push back when you hear this noise?
i'm seriously considering removing mine for the same reason. it seems to be a bit too sensitive and it doesn't give you good pedal feel when it's activated. feels panicky and just not an overall good feel to the car.
Old Jan 25, 2003 | 09:35 AM
maryzknight's Avatar
Default Re: Knocking/Rattling sounds when Braking HARD??? (YodiBrodi)
yeh it should be the abs. it makes your brake pulsate so you hear a knocking sound and the pedal pushes back at you. i dont see why you should take it off
Oknoe.
Apr 21, 2010 04:10 PM
SamC
Oct 29, 2009 08:49 PM
Xtream_V
15
Jun 24, 2007 09:46 AM
vlc92189
Mar 26, 2007 07:19 PM
RH+G
Jun 26, 2001 01:34 PM
