JDM 96-00 Civic hatch-fully built turbo, must sell
selling a 1996 civic hatch
basically heres a list of stuff the car has.
the car has only about 59 miles on it, still breaking the motor in.
i will sell the car for any reasonable price, or trade for any stock car, or bike.
will aslo part out, and sell just the shell/ or the whole motor swap-or turbo set-up.
pm me for more info
for pixs please go to < http://WWW.PICTURETRAIL.COM/JDMTHIS >
fully built motor
- cast iron darton sleeve's
- O-ringed block
- JE 8-1 commpression pistons ( coated )
- Crower connecting rods
- Je Wrist pins
- Total seal rings
- Modified oil pan with oil return
- New OEM oil pan gasket
- Unorthadox ultra-R Crank shaft pulley
- balanced crankshaft with pulley
- micro polished crankshaft
- Brand new OEM main cap bearing/crank bearing
Gude Bullfrog head package.
- Ported and polished
- 3 angle valve job
- match ported intake manifold
- head milled to block/intake manifold milled to match head
- Polished valve cover
- ARP head studs
- cometic turbo head gasket
- new OEM intake manifold gasket
- RC 310cc injectors
- AEM polished fuel rail
- B&M Fuel pressure gauge
- AEROMOTIVE adjustable fuel pressure regulator ( boost dependant )
- AEROMOTIVE external HI-performance fuel pump
- Stainless steel braided fuel lines, from gas tank back
- EARL's Fitting used for all fittings on car.
- AEM silver fuel filter
- brand new battery
Transmition
- 2000 LS tranny with ITR LSD
- ACT Heavy duty 6-puck clutch
- B&M short shifter
- Energy suspension shifter bushing kit
Turbo Set-up
- Rev Hard Cast Steel Tubular manifold(no AC)
- Rev Hard T3/T04E Hybrid Turbo eff. to 450hp
- Spearco Front mount Intercooler (28x6.5x3)
- HKS Sequential Blow Off Valve/Aluminium flange
- delta waste gate (9psi spring)
- 3" Downpipe
- 2.25" Aluminzed Mandrel Bent Piping
- Billet Map Diffuser(check valve Missing link)
- Purosil Hoses & Clamps
- Steel Braided -3 Oil Line
- Oil Return Line
- High Pressure Fuel Line
- High Pressure Silicon Hose
- Neccessary Vacuum Tee's
- Neccessary Vacuum Lines
engine-Bay
- Place Racing poly motor mounts-3 (red)
- power steering and tranny mount with energy suspension inserts
- Custom Reserve/overflow tank for radiator ( chrome-red )
Suspension
- Ground Control coil overs
- tockico 5-way adjustables
- TRUST front Strut bar (silver polished )
- Trust rear strut bar (silver polished )
- Tenzo rear tie bar ( red )
- auto power 4 point roll cage ( color matched to car )
- 95 integra GSR rear suspension set-up with disc brakes
- Rota Slipstream 16x7 flatgunmetal grey 4x100
- yokkohamma Parada Spec 2 205-60-16
Exterior
- new paint job Custom 2002 dodge viper graphite metallic
- Painted inside and out/engine bay,inside doors, under carpet inside trunk, all panles and things were removed prior to piant
- Shaved door handles
- Shaved moldings
- Shaved rear wiper
- shaved attenia
- Sparco locking fuel cap
- WW Civic Type R front lip
- WW Civic Type R Rear lip
- Oem Si side skirts
- 2000 civic si front conversion with radiator support
- 2000 civic si grill
- Oem Civic Type R smoked Headlights with city light/amber turn signals
- Oem Civic Type R power/folding mirrors
- STR rear D-Fuzer (one piece)
- OMP rear trunk Latches
- Tinted windows
- VIS Carbon fiber Hood with C/f inserts on underside
- Sparco Hood pins
- Spoon carbon fiber rear duckbill wing
- Oem Honda Mid-wing
- Apex-i N1 Cat-back exhaust
Interior
- Tenzo type-Recaro srd racing seats/2 ( red reclinable )
- Adjustable 5-way harness
- MoMo Tornado steering wheel
- Autometer c/f A-pillar 2 gauge pod
- Autometer gauge bezel 2 gauge holder
- Autometer pass/Airbag 3 gauge pod holder
- skunk2 titanium shift ****
- Si conversion
- Power windows
- Door popping selinods
- si door panels
- si center console
- si tweeter holder
- Ex cluster
Electronics
- Apex-i S-afc digital
- Greddy blackface 60mm Boost gauge
- Greddy blackface 60mm oil pressure
- Greddy blackface 60mm EGT
- Greddy blackface 65mm Air Fuel with memo playback
- Autometer 5 inch Monster RPM tach
- HKS TYPE-2 Turbo timer/warning meter ( silver )
- Greddy Profec-B Boost controller
- Raceboy shift **** with 5-functional buttons
- Skunk2 Jumper harness
- AutoPage XT-750 with LCD remote/remote start
- Multi-lock Hood lock
Sound System
- MB quartz Component system 8 piece
- MB quartz Commition show cross-over 4-units
- 500 watt cap
- Rockfordfosgate 12inch power dvc sub in banpass box
- Rockfordfosgate 2-channel 400 watt amp
- MTX Blue thunder 300 watt 2 channel amp
- Kenwood KRC Radio digital face
- Kenwood KRC double Din EQ/CD graphic display
- Custom set-up with amp and cross-overs in display in trunk
MANY OTHER LITTLE MISC THINGS THAT I PROLLY FORGOT TO ADD.
pm me for more info
fully built motor
- O-ringed block
- Je Wrist pins
- Total seal rings
- 3 angle valve job
- ARP head studs
- brand new battery
Transmition
- B&M short shifter
Turbo Set-up
- 3" Downpipe
- Oil Return Line
engine-Bay
Suspension
Exterior
- Shaved moldings
- Shaved rear wiper
- shaved attenia
- Tinted windows
- Sparco Hood pins
Interior
- Si conversion
- Power windows
- si door panels
- si center console
- si tweeter holder
- Ex cluster
Electronics
Sound System
- 500 watt cap
