450ccs, vafc, b16, and NO turbo yet. Can i run it??
Just like the title says. I have a b16 that is a few days from being turbocharged.. Im installing the 450cc and VAFC before i put the turbo on so i can make sure there isnt any problems. I can run the 450s with the vafc and lower the fuel and it will be fine correct????
Thanks for any help
Thanks for any help
why dont you just go ahead and install the vafc and wait and do the injectors later? I mean, they take like 20 minutes to do at most
Its been done before.
major idling problems?
flooded out?
you guys seem to miss the point that he has an afc.
YES it will work.
flooded out?
YES it will work.
It will work yes, but he'll still run really rich.
Why will it run really rich if he has the means to adjust it?
The answer is that it WONT run really rich if adjusted properly with the vafc.
Yes, it is more than enough. Please dont tell people it wont work, unless you know for sure that it wont. The fact is that it will work, and at less than -50%.
It should not idle any differently with or without turbo, if you turbo is spooling at idle you need a bigger turbo
That's pretty funny........a spooled turbo at idle.....hehehe
[Modified by HybridcivicLS-T, 12:20 PM 1/24/2003]
Well, i guess you forgot to read that he has an AFC, and i forgot to read what you said. Were even. drop it.
HAHA, i got the last word
j/k
He was asking if the injectors and vafc would work without a turbo, and someone said it would not idle right. All I was saying is the idle would not be any different.
Thanks for the responses. The reason is i see all these people do like 15 mods to a car all at once, then cant understand why it runs funny.. So i wanted to do the vafc and make sure the car drove and no CELS.. .then put the 450ccs in and lean it out and make sure i diidnt get any cels.. THEN put the turbo on... Ya know...
thanks for the responses.. and IIII got the last word. ahahaha...
thanks guys...
thanks guys...
I just don't know if -50 is enough to compensate for all that fuel that all. [/QUOTE]
-50 isn't enough we built a CRVtec it had RC450 and a v-afc we played around with the afc and every time vtec would come on it would fall on it face it would run fine the rest of the time. put in smaller injecters and it run fine.
I've had 450s and an SMC with no turbo in my car for a month. It idles perfectly, but its rich as hell everywhere else. Hopefully the turbo install will be done this weekend, that should solve my problem.
