b18 / b16 tranny question......
Old Jan 24, 2003 | 07:08 AM
DJ_SaNdOz's Avatar
Default b18 / b16 tranny question......
OK, I know that b series trannys are pretty interchangable; but, will a 1st gen (cable) b16 tranny bolt up & work w/ a b18c? or, will there be issues bv/c of the hydro to cable.
Old Jan 24, 2003 | 07:21 AM
slowboy's Avatar
Default Re: b18 / b16 tranny question...... (dj_sandoz)
it will bolt right up to the motor
Old Jan 24, 2003 | 08:33 AM
rioninja's Avatar
just make sure to match the clutch disk to the splines on the trans. Other than that, cake.
Old Jan 24, 2003 | 10:48 AM
SlammedHatch90's Avatar
Default Re: b18 / b16 tranny question...... ([RioninjA])
all b series motor trannys bolt up. check the clutch splines though. IMHO Ls trannys sucks. their gears are short. b16 trannys are better b/c the gears are longer and the are better for vtec. but the best tran for the job would have to be a GSR trans. but like i said..IMHO
Old Jan 24, 2003 | 11:15 AM
Malgerus's Avatar
Default Re: b18 / b16 tranny question...... (1SexyJDMGirl)
Sorry, you've got it backwards. LS gears are long, B16A tranny gears are short. Your best bet would be an S1 or J1, or if you want LSD a JDM YS1 (CRX SiR). If you really want to go nuts convert to hydraulic and run a European Type R tranny: 4.8+- gears
Old Jan 24, 2003 | 11:16 AM
DJ_SaNdOz's Avatar
i was thinking b16 b/c of shorter gearing so faster acceleration. & if teh 1st gen tranny will bolt up i won't need a cable to hydro setup. thanks ya'll.
Carlos 88CRXSi
Feb 14, 2011 12:54 PM
stevenDAtegra
Transmission & Drivetrain
10
Feb 13, 2009 01:51 PM
Da4yoA$$
Feb 7, 2007 11:19 PM
EFin' Kyle
Jul 13, 2004 06:18 PM
milanoGSR
May 13, 2003 02:43 PM
